High School Difference between these functions .
The discussion focuses on the differences between the functions f(x)=3 and f(x)=3x^0, particularly regarding their continuity at x=0 and the definition of 0^0. It highlights that both functions can be identical if f(0) is defined as 3, making the second function continuous. The conversation also delves into the contentious nature of defining 0^0, with no consensus among mathematicians on its value, which can vary depending on context. Some argue for defining 0^0 as 1 in certain cases, while others suggest it should remain undefined when considering real numbers. Ultimately, the discussion emphasizes the complexity and context-dependence of mathematical definitions.
Nader AbdlGhani
What's the difference between f(x)=3 and f(x)=3x^0 ? and why Limit of the second function when x\rightarrow0 exists ? and is the second function continuous at x=0 ?
Mathematics news on Phys.org
You can't present a function by just giving a rule, like you do. You need to give the domain and the codomain too. So what are they?
Also, what is your convention for ##0^0##? Yes, mathematicians disagree on what it should be.
Assuming R->R:
00 does not have a single common definition, so f(0) needs a separate definition in the second case. If you define f(0)=3, then both functions are identical, and the second function is continuous, otherwise it is not.
micromass said:
I disagree very much with the mathematician's explanation. They're like saying that ##0^0 = 1## is a consensus among mathematicians, it's not.
Maybe it's not. But I also think it's natural, simply for the reason that taking something to a power is something multiplicative. And therefore it makes sense to define it as the unit 1.
Sure, there are plenty of reasons why it should be ##1##. The best are set theoretic and category theoretic. But there is no consensus.
At least its a very binary decision and mathematicians can wear the shirt:
"There are 10 different answers to the equation y = 0^0"
Binary? What about defining 00 as the limit $$\lim_{x \to 0} x^{1/\log(x)} = e$$? You can also get every other number of course.
Likes jedishrfu
Yes, the function ##y^x## has an essential singularity around ##(0,0)##.
It all reduces to 1's and 0's somehow. :-)
That's a good example, I didn't see it before. It appears then that there's a whole class of possibilities too with other variations.
The vast, boring, senseless, stupid, Sisyphus-like, unprofitable and endless job to rewrite formerly beautiful and nice formulas like, e.g.
$$\exp(x) = \sum_{n = 0}^{\infty} \frac{x^n}{n!}$$
is justification enough for the choice of ##1##.
The thing is though that ##0^0 = 1## in this case only when the exponent is already seen as an integer. If the exponent is seen as a real number then it's better to leave ##0^0## undefined. So we have this weird context-dependent rule: ##y^x = 1## if ##x## is an integer and undefined when it can take on a continuous range of variables. Such a definition would be the most interesting one, but have no idea how to formalize that in a neat way. Maybe some kind of typed logic or something.
Computer languanges can deal with this very well if you take as input ##0^0##. Then it would find the type of the exponent. If the exponent is an INT, then it's ##1##, if it's a double then it's undefined. But how to do this in mathematical context?
  • · Replies 51 ·
