Difference between unique solution and particular solution
Unique solutions and particular solutions in first-order linear ordinary differential equations differ primarily in their definitions and contexts. A unique solution refers to a specific solution that satisfies given initial or boundary conditions, while a particular solution is derived from a non-homogeneous equation and represents a specific case of the general solution. The general solution encompasses both complementary and particular solutions, with particular solutions being a subset of the broader category. In essence, while all unique solutions are specific solutions, not all specific solutions qualify as unique unless they meet specific criteria. Understanding these distinctions is crucial for solving differential equations effectively.
inter060708
For 1st order linear ordinary differential equation, how do "unique solution" and "particular solution" differ?
if dy/dx = f(x,y) and partial f(x,y) with respect to y are both continuous, then there exists a unique solution within a region R.
Not really a homework question. I am just curious and sort of confused. The way I understand it is particular solution is a subset of unique solution, is that true?
If a given differential equation f(x,y,y',y'',...) = 0, this is called a homogeneous equation and it has what is called a complementary solution.
If the differential equation f(x,y,y',y'',...) = c + f(x,y), this is called a non-homogeneous equation. The solution to these types of equations are known as particular solutions.
If the ODE is linear, then the solution to the equation will be a linear combination of the complementary and the particular solutions.
If there is one solution for a given ODE with given boundary conditions, then that solution is called unique.
The differ only in emphasis. If the general solution to a differential equation is, say, y= Ae^x+ Be^{-x}, then "a specific solution" is any solution with a specific choice of A and B. The "unique solution" is a specific solution that satisfies given initial conditions.
For example, if the differential equation is d^2y/dx^2= y then the "general solution' is, as before, y= Ae^x+ Be^{-x} for any constants A and B. A specific solution (notice the use of the indefinite article, "a") might be y= e^x- 2e^{-x} where I have arbitrarily chosen A= 1, B= -2. The unique solution (notice the use of the definite article, "the") to the differential equation, d^2y/dx^2= y with the initial conditions y(0)= 1, y'(0)= 0, is (1/2)e^x+ (1/2)e^{-x}.
Of course, the "unique solution" to the given "initial value problem" is one of the infinite number of "specific solutions" to the differential equation.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
