Different type of solenoid design help
Juan Motta seeks guidance on estimating the magnetic field (gauss) of a non-cylindrical solenoid design he is planning to build. He acknowledges his beginner status in physics and is unsure how to apply existing formulas for cylindrical coils to his unique shape. Forum participants clarify that if the coil's length is significantly greater than its width, cylindrical formulas can still be used. However, for shorter coils, they recommend using numerical integration methods and the Biot-Savart law to calculate the magnetic field. The discussion emphasizes the complexity of calculating magnetic fields for non-standard solenoid shapes.
JuanMotta
Hi my name is Juan Motta and i´m new in this forum, I`m a total begginer in physics. I´m planning to build a solenoid (air coil or iron coil, i don´t know) with different form, like this:
http://www.divshare.com/img/thumb/19310413-b22.jpg
And i have some cuestions about, because i have some formulas from this forum but they are applicable with a cylinder form, how can i estimate the gauss from this type of solenoid?
Thanks and sorry about my english
Juan Motta
What do you mean what "gauss", the magnetic flux density varies from place to place.
If you are referring to the approximately constant field inside the solenoid, there is a well known formula for it.
Sorry... and "Yes" is the approximately constant field inside the solenoid, but i don´t know how can i estimate in this type of shape because is not a cylinder...
As long as the coil length is much larger than the "width", the shape should not be important. Just use the formula for cylindrical coils. If the coil is not long compared to the width, you will need integrations to calculate it (probably numerically).
Yes, the coil is not long, is short, so integrations for the for calculate the radius?... I think I'm very far to get to know that...
Look into amperes law, the field can be quite difficult to find for current densities without good symmetry
You cannot use Amperes law (no straight wire of infinite length), you need Biot-Savart to calculate the magnetic field.
thank you for all your answers
  • · Replies 51 ·
  • · Replies 43 ·
  • · Replies 52 ·
