General Solution for y'' + 6y' + 8y = 2t + et
The general solution for the differential equation y'' + 6y' + 8y = 2t + et is determined to be y(t) = k1e-2t + k2e-4t + yp. To find the particular solution yp, it is suggested to use a linear function of the form b + ct to address the 2t term. After testing various forms, yp is refined to (1/4)t - (3/16) + (1/15)e^t. The final solution incorporates the corrections for both the linear and exponential components. The discussion emphasizes the importance of careful substitution and adjustments in the solution process.
cse63146
Compute the general solution of y'' + 6y' + 8y = 2t + et
after using determinants, I found the general solution to be y(t) = k1e-2 + k2e-4 + yp
To find yp, I would make it equal to yp = aet find its first and second derivates, and substitute them back into y'' + 6y' + 8y , but what do I do about the 2t?
You can do some clever guess work. You can make sure that y'' is 0 by taking some linear function. This simplifies your problem to 6y'+8y=2t. Since we took a linear function y' will be a constant so this will reduce your problem to constant+8y=2t. A function of the form b+ct should suffice.
would yp = t be a good guess?
since y'p = 1 and y''p = 0
But 6+8t \neq 2t, so no. Try b+ct as suggested in my previous post.
how about \frac{1}{4}t - \frac{3}{16}
so 6(1/4) + 8(\frac{1}{4}t - \frac{3}{16}) = 3/2 + 2t - 3/2 = 2t
so when considering et, I would let yp =\frac{1}{4}t - \frac{3}{16} + e^t ?
The linear term is correct now, however if we plug in e^t we get, e^t+6e^t+8e^t=15e^t!=e^t. So you have to divide by 15.
oops
it should be \frac{1}{4}t - \frac{3}{16} + ae^t
and a would be 1/15
Correct.
Thank you for all your help.
You're welcome.
Pretty sure you meant to write y(t) = k1e-2t + k2e-4t + yp here.
Oops (again).
Yeah, I did. Thanks.
  • · Replies 25 ·
