Differential equation with sphere
The discussion centers on the evaporation of a spherical mothball with an original radius of 1.2 cm, which reduces to 1 cm over 180 days. The rate of evaporation, represented by the differential equation -dr/dt = c1 * 4πr², is proportional to the sphere's surface area. The user initially calculated the time for the radius to shrink to 25% of its original size as 2694 years and the time for the volume to halve as 233.82 years, which were incorrect due to a unit conversion error. The correct calculations, once adjusted to days, yield accurate results.
  • Understanding of differential equations
  • Knowledge of surface area calculations for spheres
  • Familiarity with initial value problems
  • Basic skills in unit conversion
  • Study the method of separation of variables in differential equations
  • Learn about the physical principles behind evaporation rates
  • Explore the relationship between surface area and volume in geometric shapes
  • Practice unit conversion techniques in mathematical problems
Students studying calculus, particularly those focusing on differential equations, as well as educators and anyone interested in the physical applications of mathematics in real-world scenarios.
dinospamoni
A spherical mothball of original radius 1.2 cm slowly
evaporates such that 180 days later, its radius is only 1 cm.
Physically, the rate of evaporation dr/dt is proportional to the
surface area of the sphere. Determine a) the time required for
the radius of a new mothball to shrink to 25 percent of its
original radius, and b) the time required for the volume of a
new mothball to become half of its original value.
SA= 4 pi r^2
r(0)=1.2
r(180)=1
I started by saying -dr/dt = c1 4 pi r^2
where c1 is a constant of proportionality
Then through separation of variables I found that
1/r = 4 pi c1 t + c2
after imposing the initial conditions I found c1=7.383*10^-5 and c2=.833
so I have
1/r = 4 pi (7.383*10^-5) t + .833
and this gives me answers of
1) 2694 yr
2) 233.82 yr
but these aren't right. Any ideas of where I went wrong?
Your equation give the right values for t=0 and t=180, so I think you have some calculation error in the final steps.
I seriously doubt that mothballs evaporate like that. It would mean that evaporation is proportional to the square of the surface area.
Yeah, I think I might have the wrong initial equation, but I'm not sure of what it could be
SA= 4 pi r^2
r(0)=1.2
r(180)=1
so I have
1) 2694 yr
2) 233.82 yr
1/r = 4 pi (7.383*10^-5) t + .833 looks ok. Why are you giving the times in yrs? Don't you mean days? And I'd check those again.
Wow. Don't I feel silly. I was working on several problems at once and I guess I forgot this one was in days, not years and it worked. Good eye! Also, Thanks a ton!
  • · Replies 30 ·
