Differential equations: period of a mass on a hanging spring
The period of simple harmonic motion for a mass hanging from a spring is defined by the formula 2π√(l/g), where l is the extension beyond the spring's natural length at equilibrium. The differential equation governing this system is my'' + ky = mg, where m is mass, k is the spring constant, and g is the acceleration due to gravity. The discussion highlights the importance of correctly setting initial conditions, specifically y(0) = L + l and y'(0) = 0, to accurately model the system's behavior. The method of variation of parameters (VoP) was discussed but deemed unnecessary for finding the particular solution, which can be derived more simply.
  • Understanding of simple harmonic motion principles
  • Familiarity with differential equations, specifically second-order linear equations
  • Knowledge of initial conditions in mechanical systems
  • Experience with methods of solving differential equations, including method of undetermined coefficients and variation of parameters
  • Study the derivation of the formula for the period of a mass-spring system
  • Learn about the method of undetermined coefficients in solving differential equations
  • Explore the implications of initial conditions on the behavior of oscillating systems
  • Investigate the applications of simple harmonic motion in real-world scenarios
Students studying physics or engineering, particularly those focusing on mechanics and oscillatory systems, as well as educators seeking to clarify concepts related to differential equations and harmonic motion.
OEP
Hey guys. This was a homework problem (I could never figure it out) and I asked my instructor for help as well as researching on the Internet, but still no dice. It seems basic enough but it bothers me that I still don't know how to solve it.
Show that the period of the simple harmonic motion of a mass hanging from a spring is 2 \pi \sqrt{l/g}, where l denotes the distance beyond the spring's natural length when the mass is at equilibrium.
I figured the differential equation we should solve is a simple mass-on-a-spring case but with the external force being mass-gravity. That is:
my'' + ky = mg.
The general solution looks something like:
c_1 cos(\sqrt{\frac{k}{m}}t) + c_2 sin(\sqrt{\frac{k}{m}}t) + y_p
For now, let's say:
\omega := \sqrt{\frac{k}{m}}
Now we need to solve for y_p.
I did this in the two ways I know how, that being method of undetermined coefficients and variation of parameters. Both of them ended in some pretty nonsensical solutions (0 = mg??).
For the sake of comparison, after using the method of variation of parameters, I ended up with this particular solution and resulting position function:
y_p = \frac{g}{\omega(1+\omega)}
(I know that can't be right since it's a constant.)
y(t) = (L - \frac{g}{\omega(1+\omega)}) cos(\omega t) + \frac{g}{\omega(1+\omega)}
Where L is the natural length of the spring (I used the initial conditions y(0) = L, y'(0) = 0).
Anyone want to take a whack at it or point me to where someone already has?
You usually want to do this by working in a variable where u=0 is the equilibrium position. Then mu''+ku=0. I.e. y=u+mg/k. What's wrong with that? A particular solution in the variable y is y=mg/k, isn't it? No call for variation of parameters or anything.
my'' + ky = mg.
For now, let's say:
"where l denotes the distance beyond the spring's natural length when the mass is at equilibrium."
The initial conditions "y(0)= L, y'(0)= 0" give no motion at all! The spring is sitting motionless at its natural length so there is no force on it. You want y(0)= L+ l, y'(0)= 0.
I get the feeling there's some sort of progression of logic that does involve variation of parameters given that this is from a math book and is from a chapter that is trying to teach how to use MUC/VoP.
There wouldn't be? I thought of it like this:
y(0) = L would be like if the spring were hanging with no mass on it. The spring, under its own weight, wouldn't stretch noticeably beyond its natural length. As soon as you attach a mass to it and let the oscillations settle, the mass would be at length L + l.
A particular solution IS a constant. If you used VOP and got yp=g/(w*(w+1)) you came pretty close but you made a mistake. Not surprising, VOP is complicated. You should have gotten g/w^2=g/sqrt(k/m)^2=g/(k/m)=mg/k. But VOP is massive overkill for that. You can tell a constant is a solution by inspection.
Since you mentioned that, I remembered another time where I solved for a particular solution mg/k with just algebra, but it didn't occur to me to use it as y_p.
