Differential Equations through Power Series Expansion
4 replies · 5K views · last reply
IniquiTrance
When solving diff-eq's given initial values, e.g.
y'' - 2y ' + y = 0
y (0) = 0
y ' (0) = 1
Can one assume immediately that
y(0) = c0
and y ' (0) = c1
Since these are the first 2 terms in the series?
Thanks!
One can assume that
[tex]y(x) = \sum_{n = 0}^\infty c_n x^n.[/tex]
Plugging in x = 0 gives y(0) = c0.
Differentiating
[tex]y'(x) = \sum_{n = 0}^\infty n c_n x^{n - 1}[/tex]
and taking x = 0 gives y'(0) = c1.
So you can show it, if you assume the series expansion to hold.
You can't "immediately assume" that y(0)= c0 because you haven't yet said what "c0" means! You can immediately assume that y(0)= 0 because you are told that. You are also told that y'(0)= 1 and you can calculate that y"(0)= 2y'(0)- y(0)= 2. Further, since y"= 2y'- y for all x, y"'= 2y"- y' and y"'(0)= 2y"(0)- y'(0)= 2- 1= 1.
Then y""= 2y"'- y" so y""(0)= 2y"'(0)- y"= 2- 2= 0. So far, y(x)= 0+ 1x+ (2/2)x2+ 0x3= x+ x2.
You can continue differentiating y"= 2y'- y to find the higher degree terms.
So if we do assume that a solution will take the form of:
Then as CompuChip says, it follows that whatever this series looks like, c0 will be the only term without an x variable, and is thus equal to y(0).
Likewise, when the series is differentiated, c1 will be the only term without an x, and thus will equal y '(0).
Is this true?
Is this true?
Yes, of course. That's just the MacLaurin series:
[tex]\sum_{n=0}^\infty \frac{f^{(n)}(0)}{n!}x^n[/tex]
The coefficient of xn for every n is the nth derivative divided by n!.
