Differential Equations - Variation of Parameters problem
2 replies · 4K views
Nubcakes
As the name suggest, this problem is an undetermined coefficients problems where variation of parameters is necessary to solve. As with my previous question; This is not a homework problem, but it is out of the textbook so I figured this would be the appropriate place to ask if I am doing it correctly.
Here is the initial problem where one is asked to find the general solution;
I know there are at least 4 different approaches to this problem, but nearly all will not work well on other similar problems. However, from what I can understand the "Variation of Parameters" technique can be used to solve almost any differential Equation problem in this format so long as you do not encounter an impossible-to-solve integral EXA:{ln(ln(x))}
That being said; here is my attempt at the problem using "Variation of Parameters";
Simple question; Did I do it right? If not where did I screw up?
No, "undetermined coefficients" and "variation of parameters" are two completely different methods of find a specific solution to a non-homogeneous linear equation.
In your equation for v'2 you seem to have neglected a factor of cos(x) on the right. You have cos2(x) from the differential equation. To solve for v2' you have to multiply by another cos(x). You should have v2'= cos3(x).
Whoops... I should have caught that that problem with V2. Anyway thanks for the help, got to remember to keep a close eye on everything in these problems... its pretty easy to loose track of parts of the problem since there are so many parts.
