Differential of Multiple Linear Regression
1 reply · 2K views
fny
Say you have a log-level regression as follows:
$$\log Y = \beta_0 + \beta_1 X_1 + \beta_1 X_2 + \ldots + \beta_n X_n$$
We're trying come up with a meaningful interpretation for changes Y due to a change in some Xk.
If we take the partial derivative with respect to Xk. we end up with
$$\frac{dY}{Y} = \beta_k \cdot dX_k$$
which implies that if Xk. increases by 1, you expect Y to increase by 100βk percent.
Can someone walk through the calculus to get from this
$$\frac{\partial}{\partial X_k} \log{y}= \frac{\partial}{\partial X_k} (\beta_0 + \beta_1 X_1 + \beta_1 X_2 + \ldots + \beta_n X_n)$$
to this
$$\frac{dY}{Y} = \beta_k dX_k$$?
I'm particularly confused about how one transitions from a partial derivate to a total derivative.
In general one cannot make that transition. The second last formula is correct but the last is not, unless there is no dependence between ##X_k## and any of the other ##X_j##s. A corrected version of the last formula is:
\frac{dY}{Y} = \sum_{j=1}^n \beta_j dX_j
To get the total derivative wrt ##X_k## we use the total derivative formula, for the case where ##Y## is a function of ##X_1,...,X_n##:
$$\frac{dY}{dX_k}=\sum_{j=1}^n \frac{\partial Y}{\partial X_j} \frac{dX_j}{dX_k}$$
In this case we have ##Y = \exp\left(\beta_0 + \sum_{k=1}^j \beta_j X_j\right)## so that ##\frac{\partial Y}{\partial X_j} = \beta_jY##, and we also have ##\frac{d X_k}{d X_k}=1##, so that the total derivative becomes:
$$\frac{dY}{dX_k}=Y\left(\beta_k + \sum_{\substack{j=1\\j\neq k}}^n \beta_j \frac{dX_j}{dX_k}\right)$$
This reduces to the formula you wrote above for the total derivative if all the ##\frac{dX_j}{dX_k}## are zero, ie if there are no dependences between ##X_k## and any of the other ##X_j##.
What we can say is that ##Y## increases by ##Y\beta_k\delta X_k## if ##X_k## increases by ##\delta X_k## and all other variables do not change.
