Differentiate trigonometric equation
The forum discussion centers on differentiating the expression (Ua - Ub)' * C * r with respect to the variables θ, Φ, and ψ. The rotation matrix C is defined as a 3x3 matrix involving trigonometric functions of these angles. Participants clarify that the differentiation should be performed separately for each variable, treating (Ua - Ub)' as a constant. The final answer involves using the skew-symmetric matrix derived from the rotation matrix C.
  • Understanding of matrix calculus and differentiation
  • Familiarity with rotation matrices and their properties
  • Knowledge of trigonometric identities and derivatives
  • Basic linear algebra concepts, particularly vector operations
  • Study the properties of skew-symmetric matrices in linear algebra
  • Learn about the application of rotation matrices in 3D transformations
  • Explore advanced differentiation techniques in matrix calculus
  • Review the chain rule and product rule as applied to vector functions
Students and professionals in mathematics, physics, and engineering, particularly those working with robotics, computer graphics, or any field involving 3D transformations and derivatives.
9988776655
a) Differentiate the following equation with respect to:
1) θ
2) Φ
3) ψ
(Ua - Ub)' * C * r
where:
C is a 3 x 3 rotation matrix:
[ cos θ cos ψ, -cos Φ sin ψ + sin Φ sin θ cos ψ, sin Φ sin ψ + cos Φ sin θ cos ψ]
[ cos θ sin ψ, cos Φ cos ψ + sin Φ sin θ sin ψ, -sin Φ cos ψ + cos Φ sin θ sin ψ]
[ -sin θ, sin Φ cos θ, cos Φ cos θ ]
Ua is a 3x1 column vector:
[Ua_x]
[Ua_y]
[Ua_z]
Ub is a 3x1 column vector:
[Ub_x]
[Ub_y]
[Ub_z]
r is a 3 x 1 column vector:
[r_x]
[r_y]
[r_z]
' means transpose
Show your working out.
derivative of:
sin x is cos x
cos x is -sin x
Let:
θ = theta
Φ = phi
ψ = psi
Expanding:
r_z*((Ua_x - Ub_x)*(sin(phi)*sin(psi) + cos(phi)*cos(psi)*sin(theta)) - (Ua_y - Ub_y)*(cos(psi)*sin(phi) - cos(phi)*sin(psi)*sin(theta)) + cos(phi)*cos(theta)*(Ua_z - Ub_z)) + r_y*((Ua_y - Ub_y)*(cos(phi)*cos(psi) + sin(phi)*sin(psi)*sin(theta)) - (Ua_x - Ub_x)*(cos(phi)*sin(psi) - cos(psi)*sin(phi)*sin(theta)) + cos(theta)*sin(phi)*(Ua_z - Ub_z)) + r_x*(cos(psi)*cos(theta)*(Ua_x - Ub_x) - sin(theta)*(Ua_z - Ub_z) + cos(theta)*sin(psi)*(Ua_y - Ub_y))Answer in book:
(Ua - Ub)' * (skew(C * r))
Where skew is the skew symmetric matrix
ie skew (x y z) =
[0 -z y]
[z 0 -x]
[-y x 0]
1) θ
2) Φ
3) ψ
(Ua - Ub)' * C * r
The above is not an equation -- no = in it.
9988776655 said:
where:
[Ua_x]
[Ua_y]
[Ua_z]
[Ub_x]
[Ub_y]
[Ub_z]
[r_x]
[r_y]
[r_z]
' means transpose
derivative of:
sin x is cos x
cos x is -sin x
Let:
θ = theta
Φ = phi
ψ = psi
Expanding:
ie skew (x y z) =
[0 -z y]
[z 0 -x]
[-y x 0]
The problem isn't clear to me. From your problem statement, are you supposed to find three separate derivatives or are you supposed to find the derivative with respect to θ, and then differentiate that function with respect to Φ, and then, finally, differentiate that function with respect to ψ?
As I understand this problem, expanding the original expression as you did makes things worse. ##U_a## and ##U_b## don't involve θ, Φ, or ψ, so ##(U_a - U_b)^T## can be treated as a constant, using the differentiation rule ##\frac d {dx}(k f(x)) = k \frac d {dx} f(x)##. Also, r doesn't appear to involve θ, Φ, or ψ, so differentiating Cr would be a lot simpler.
Hi,
Sorry for not being specific enough. You can write
y = (Ua - Ub)' * C * r;
then find
1) ∂y/∂θ
2) ∂y/∂Φ
3) ∂y/∂ψ
so find three separate derivatives.
Yes I see that (Ua - Ub)' is constant.
