Difficult function of a function problem
  • Thread starter contempquant
    Function
10 replies · 2K views · last reply
contempquant
I'm trying to solve a double derivative of a function of a function problem, but can't seem to be able to differentiate once. I have the formula given by the chain rule,
find [tex]\frac{d}{dz}{E}(\bar{r})[/tex] when [tex]{E}(\bar{r})={E_0}(\bar{r})e^{ikz}[/tex] and [tex]\bar{r}[/tex] is a function of z.
I have used [tex]\frac{df}{dz}=\frac{dg}{df}\frac{df}{dz}h(x)+\frac{dh}{df}\frac{df}{dz}g(x)[/tex]
where [tex]g(x)={E_0}(\bar{r})[/tex] and [tex]h(x)=e^{ikz}[/tex]
and [tex]f=E(\bar{r})=E_{0}(\bar{r})[/tex]
I have then substituted in for these giving,
[tex]\frac{d{E_0}(\bar{r})exp^{ikz}}{dz}[/tex]=[tex]\frac{\partial{E_0}(\bar{r})}{\partial{E}(\bar{r})}\frac{\partial{E}(\bar{r})}{\partial{z}}*e^{ikz}+\frac{\partial{e^{ikz}}}{\partial{E}(\bar{r})}\frac{\partial{E}(\bar{r})}{\partial{z}}*E_{0}(\bar{r})[/tex]
The problem is i don't know how to differentiate any of the individual partial differentials because [tex]\bar{r}=r(z)[/tex], r is dependent on z. Any ideas? i really don't know how to start this one, and when this is done i have to differentiate it again. I'm sure if i can find out how to do this once i can do the second derivative but can't seem to do this one.
apparently the final solution is,
[tex](\frac{\partial^{2}E_{0}}{\partial{z}^{2}}+2ik\frac{\partial{E_0}}{\partial{z}}-k^{2}E_0)e^{ikz}[/tex]
So in [tex]\mathbf{r}=x\mathbf{i}+y\mathbf{j}+z\mathbf{i}[/tex] and [tex]r=\sqrt{x^{2}+y^{2}+z^{2}}[/tex] then you use the chain rule in the following way:
[tex] \frac{d}{dz}E_{0}(r)=\frac{dE_{0}}{dr}\frac{dr}{dz}[/tex]
sorry, that third line under relevant equations: [tex]f=E(\bar{r})=E_{0}(\bar{r})[/tex]
should read
[tex]f=E(\bar{r})=E_{0}(\bar{r})e^{ikz}[/tex]
I think that might change the answer you gave hunt_mat?
well that's the thing because [tex]\bar{r}[/tex] isn't defined in the book (Milonni, Lasers) but only the scalar version of r is defined, which is as you wrote it above,
[tex]r=\sqrt{x^{2}+y^{2}+R^{2}}[/tex]
Where [tex]z=R[/tex], R is the distance along the z axis
So this r is a vector? I think that either you can take E_0 as a function of x, y, and z or that it only has radial dependence.
so the differential of [tex]\frac{\partial{E_0}(\bar{r})}{\partial{Z}[/tex] is just one?
how do i do the differential,
[tex]\frac{\partial{E_0}(\bar{r})}{\partial{E}(\bar{r}) }[/tex]? as it's taken w.r.t the starting function?
* [tex]\frac{\partial{E_0}(\bar{r})}{\partial{Z}}[/tex]
I think that may be the case, having had a little look at the book on amazon, it seems like it's poor notation. I think the notation means that E_0 is a function of x,y and z and you just write down: the derivative as you have, that is how I would view the problem.
