Difficulty understanding evolution
138 replies · 19K views
Mutations of markings don't stop, it's just that those which occur don't contribute to any further improvement.
Biology news on Phys.org
By the way, what clicked for me is I was just imagining one animal, I forgot that there must have been loads and loads of camo variations in each generation. Maybe this is where creationists go wrong, so easy to miss something huge when you try to collaborate
Ah now I am stuck, how do they know they don't contribute to not carry on? (My apologies in advance)
The genes don't 'know' anything, It's down to whether or not they contribute to improving chances of survival.
Quite a lot of mutations are neither helpful or harmful, so they are neither selected for or against.
They remain in the population as a variation, but are of little survival significance, so don't become widespread as the norm for that species.
In other words they are not factor for the future evolution of that species.
Human eye colour might be an example
They remain in the population as a variation, but are of little survival significance, so don't they become widespread as the norm for that species.
That helps, and of course they don't know anything, is it the fact that the isolated groups have survived forcing through the strong successful traits and as the species has spread out and heavily populated, now any real mutation will fizzle out. Is that a good analogy of how this happens? cos when you say they are not of any more benefit, its difficult not to relate that to mindfulness unless explained in a bit more detail as to how and why these traits just stop
It's not mindfulness, it's a matter of the organism surviving long enough to reproduce before getting eaten or being killed in some other way.
But what's the governing factor in deciding when why or how a mutation will not pass down anymore? you said if the mutations are not useful anymore they just don't pass on. That really does emply mindfulness without an explanation of how they don't pass on. If they don't have a mind (which we agree on) then how can they (or the gene pool) know they are not needed?
Its like a lottery ball dispenser, let's say to stop it you have to switch it off, its generating random balls, then it suddenly switches itself off because its done enough, its finally got the numbers right. That can't make sense unless there is a deeper understanding of why it suddenly switched off
Natural selection* is the answer. If the mutation lowers an organism's fitness then it makes it less likely to reproduce, because the mutation affects fertility directly or it decreases survival chance meaning the organism will have fewer (or no) children. If a mutation leads to more offspring then in the next generation a higher proportion of the population will have that mutation.
*there are other causes like sexual selection but let's stick with the basics for now.
The governing factor is simply survival.
If a mutation makes no difference to survival or reproduction then it doesn't become more widespread in the gene pool over several generations.
If there IS a survival advantage it WILL eventually become widespread in the gene pool.
That is how evolution works, and after a long time of many accumulated changes you have in effect a new species.
Evolution is a gradual process, there are not sharp boundaries in time where some ancient species dies out to be replaced by an improved model.
Lets say though for example a big blue dot on a creature has emerged over years of survival of the fittest, its great for the creatures survival as it puts off its predator (this is hypothetical) so a perfect round blue dot has occurred eventually. This is probably quite standard I would say. So let's say that one of the offspring has a tiny mutation and that perfect blue dot now has a tiny little dot on the outline of it. It still deters predators and does not effect the survival rate, in fact, it reproduces more offspring. So why now does that useless little extra bit not remain in the future? it hasnt inhibited anything, and we see very perfect examples like the black widow spider, perfect red dot on its back, never ever going to turn into an oval, and were saying that its simply because the dot works?? I really find a problem with this
Im sorry the black widow was a really bad example, let's stick with my first example, I am sure there is an animal with a perfect dot in a certain place to use instead of the black widow (which I realized has a non descript shaped red part)
Adamchiv said:
Is there some sort of radial symatry in these colourations that makes these markings very easy to form rather than a complex process where millions of these animals die until its good enough
Here is a wikipedia entry on eyespots
It talks about why they can be adaptive but also mentions some of the genes involved in their development.
Some of the genes involved make diffusable signalling molecules. They would diffuse out in a circular pattern from a small source (perhaps a few cells).
This would pattern the cells and explain circular shapes.
In that case the mutation would stay as it's neutral. Mutations can be advantageous, neutral or disadvantageous. The overwhelming majority of mutations in nature are neutral and stick around. A smaller number are slightly advantageous or slightly disadvantageous. These proliferate/are weeded out slowly over time. A rare few are strongly advantageous or disadvantageous.
Adamchiv said:
By the way, I meant it requires a small isolated group for changes to pass down to a full group type of thing..
Not necessarily. If the offspring of one individual all carry over a beneficial trait that they can pass on to their offspring and so on and so on, the descendants of the original organism with that trait can, over time, out compete the others of their species and the trait can end up being in all of the individuals of the species. Isolated groups can and do tend to diverge from their original population rather quickly, as they are usually isolated in a different environment and don't have any mixing with the original genes that can remove or diminish various mutations.
Adamchiv said:
So how come mutations on markings stop once it is succesful? Is it because those traits passed on in a big non isolated group become stronger?
Mutations don't stop. Variations in alleles (unique genes for a certain trait such as fur color, which arise from mutations) will tend to make the trait fluctuate slightly around some average value or particular pattern, but as you get away from this value the individual either becomes less fit or the change becomes less significant. Natural selection will tend to weed out those individuals that are less fit, and the other trait won't be selected for because it doesn't confer a tangible advantage.
If, for any reason, that particular creature with the red outline survives to have offspring, then all of its genes will be passed on, even the ones that confer a neutral or negative trait (if it has any). So even if the red outline isn't contributing to its fitness at all, it can still be passed on through chance or because the creature was more fit due to other genes. This is exactly what we see in many, many cases. In your example, if the red outline is due to a change in genetics that can be passed on to its offspring, then the trait will remain in the population's gene pool until all of its descendants have either died without leaving offspring, or the trait is lost due to another mutation that then spreads.
Thats very helpful actually, that's led me a bit closer, I can work on that as a foundation and look into it
Mutations don't stop. Variations in alleles (unique genes for a certain trait such as fur color, which arise from mutations) will tend to make the trait fluctuate slightly around some average value or particular pattern, but as you away from this value the individual either becomes less fit or the change becomes less significant. Natural selection will tend to weed out those individuals that are less fit, and the other won't be selected for because it doesn't confer a tangible advantage.
Ahh so we have some some variencies among species, but they only pass on down that blood line and so then it doesn't effect the overall species and the trait is more likely to die out
Advantageous traits get passed down through generations of descendants precisely because they are advantageous (for survival).
Nature has no policy of deciding which members of a species are permitted to mate, so no pure 'bloodlines' exist.
They all merge as generation go by.
Traits which harm an individual's chance of reproducing tend to disappear in the overall population
Traits confering an advantage for reproducing will after several generations become the normal for that species.
There are some interesting variations on that theme though. a bee colony is one.
Here there is only a single reproducing queen bee, most of the colony members are infertile.
In my opinion though, the beehive is the creature, and the worker bees, drones etc are more analogous to
cells in animals.
cells in animals.
Thats a very interesting point, I remember richard dawkins describing worker ants as very similar to our bodily cells. Can I thank you rootone for your outstanding patience and information! You have been a real help with this
Yeah, he tends to do that, but don't let's overdo the praise, it'll go to his head :oldlaugh:
Lol You have all been very very helpful but how this person didnt lose their temper with me is very worthy of praise. I tend to find another problem within a solution, like god of the gaps but rather study of the gaps
I have a trait of not losing my temper, this has been an advantage so far.:biggrin:
Adamchiv said:
Hi
I am and athiest and I believe on evolution, but there is an aspect of it that I can't get to grips with...
Thanks for any help with this
I really, REALLY do not mean to talk down to you, but your questions suggest that this is not the right forum for us to begin explaining at that level. It would take a looong time.
1: If you have too little idea of the nature of cell biology and reproduction, then first check out some school texts on biology or do some scouting around Wikipedia and even google.
2: If you do understand the role of nucleic acids in cell function and reproduction, and of cells in the construction of your body, then read some really sound basic introductions to evolution. I should recommend Daniel Dennett's "Darwin's Dangerous Idea" and maybe Dawkin's "The Selfish Gene" ((preferably 2nd or 3rd edition). They are not the only good books around, because semi-popular books on Darwinism have been a drug on the market for years now, but they are sound, make pleasant reading and are easily understood.
The reason I advise this is that as they stand, your questions are biological at a level similar to asking a physicist "Why doesn't the moon fall on my head, if as you say, it is attracted to me by gravitation." Yes, it is true that the attraction exists, but you see...
If you encounter any difficult points on the way, by all means come back and ask, but please keep the questions explicit.
"why is it that our arms don't have big lumps all over them or, our ribcage have random points sticking out of each one, or an extra toe poking out the side of our foot."
-- Some do! I worked in a hospital and I saw myself many abnormal newborns, most of which dying at once or soon after. This is natural selection at work.
The healty ones live on, the dying ones die. No one said it was a happy process.
The regular use of Caesarean sections is having an impact on human evolution, say scientists.
More mothers now need surgery to deliver a baby due to their narrow pelvis size, according to a study.
Researchers estimate cases where the baby cannot fit down the birth canal have increased from 30 in 1,000 in the 1960s to 36 in 1,000 births today.
Historically, these genes would not have been passed from mother to child as both would have died in labour.
Researchers in Austria say the trend is likely to continue
"Without modern medical intervention such problems often were lethal and this is, from an evolutionary perspective, selection.
"Women with a very narrow pelvis would not have survived birth 100 years ago. They do now and pass on their genes encoding for a narrow pelvis to their daughters."
http://www.bbc.com/news/science-environment-38210837
Thats very interesting and once again another point that I forgot to think about, that is imperfection for sure
But this is a significant part of the answer to the original question, which I take to be more along the lines of "why are there not more mutations of a fairly cosmetic nature?" I.e. how is natural selection so effective at weeding at even small imperfections?
Potential mates care about about genetic fitness. A lop-sided face can be a consequence of a childhood illness, so we have evolved to find such faces less attractive.
Yes that is very much to do with some of my problem I have understanding. That makes a lot of sense to me. Heres another issue, how do the male and female sexual organs develop side by side to work so well, same for the sperm and the egg. I kind of imagine it to go way back to bacteria or slightly after, but I really really don't understand how. Because they must develop and evolve separate from each other
It depends what you mean by working well together. Many aspects of this, in many species, are an arms race. The female side raises barriers so that only the fittest make it ( at the sperm level and higher), while the male side wages war with rivals, e.g. by leaving a plug in place or inflicting physical damage on the female.
Adamchiv said:
Heres another issue, how do the male and female sexual organs develop side by side to work so well, same for the sperm and the egg. I kind of imagine it to go way back to bacteria or slightly after, but I really really don't understand how. Because they must develop and evolve separate from each other.
If you can find the time, read Matt Ridley's book: 'The Red Queen: Sex and the Evolution of Human Nature'.
Thats great I'll take a look at that, it really puzzles me but I know science will have the answer
Yeast (a eukaryote and a fungi) and some bacteria have mating types, but they don't have sex organs. DNA exchange should only proceed between individuals with different mating types.
Although DNA is exchanged between these different mating types, they don't have sex organs or specialized reproductive cells like sperm, eggs, pollen, ovules (plant equivalent of eggs).
Sex organs are restricted to metazoan animals and plants have sex cells as a specialized sub-set of all the cells in their bodies.
Sex organs support the production of the gametes and are used for transferring gametes (sperm, pollen) so they can meet up with and fertilize eggs and ovules.
Some animals are both male and female (like most plants) at the same time. Some are first one sex than the other.
Again, selection has selected for them to work (either together or a lone) to achieve their function of reproduction (the most important biological property).
They don't always have to work together. Some worms will stab through the females skin with their "penis-like-thing" the get their sperm in the females body cavity where they will eventually find the eggs to fertilize. This requires little coordination with the females sex organs.
Some animals have sophisticated sperm storing organs that can keep sperm viable for months for fertilization long after copulation.
Just to add to the complexity, sex chromosomes can also evolve and change.
Interesting, do you think that the human genitallia both male and female evolved independantly of each other for a long time? Was there a point when there was maybe one organism that reproduced and a split happened causing a male and female to evolve from it, one carrying the male components and the other the female components (in terms of reproductive cells) I don't mean suddenly there was man and woman like the biblical stories. I guess what I am trying to say is there must have been a point where male and female happened from when we evolved from bacteria up until we became two separate genders
The two sexes had to evolve together in that they make haploid sex cells (sperm and eggs).
Haploid cells have only one copy of each chromosome. When the egg and sperm combine, they then have two copies of each chromosome (one from each parent), which makes them diploid, the normal state for animals. If they were haploid they would probably die before reproducing. If this were done without making the sex cells haploid, each generation would double its number of chromosomes, which would end badly.
Haploid cells are made by meiosis (special cell divisions that reduce the chromosomal number) rather than the more common mitosis (cell division without changing the chromosomal number). This requires males if there were females and visa versa. They have to had developed together.
This likely occurred very, very early on the history of life. Most likely when all life was still unicellular with perhaps some very simple multicellular organisms. By the time that the first fish species evolved, sexual reproduction had already been in place a long time.
