Potential of Point A to Point B in Difficult RC Circuit
The discussion focuses on finding the potential between points A and B in a circuit with a 10.0V battery and resistors. Participants mention using Ohm's Law and equivalent resistance formulas, but express confusion due to the disconnection between points A and B. The importance of applying Kirchhoff's Current Law (KCL) is highlighted, with suggestions to ground the circuit for analysis. It's noted that there is no current flowing through the middle branch of the circuit. The conversation emphasizes the complexity of analyzing RC circuits, particularly in transient conditions, which may be encountered in engineering studies.
AGGENGR
Warrning: Posting template must be used for homework questions
Find the potential of point a with respect to point b in the figure (Fighttps://s.yimg.com/hd/answers/i/1ffe0f8aeaf145679cde38f7812b1c7f_A.png?a=answers&mr=0&x=1413484693&s=0943630e47eb74ae023909f7d39f74e3 ure 1) .
If points a and b are connected by a wire with negligible resistance, find the magnitude of the current in the 10.0V battery.
V=IR, Req=R1+R2, 1/Re = 1/R1+1/R2
So basically added up the resistors in series on the side getting 4 ohm and 3 ohm respectively. I am stuck because the a-b is disconnected which is something i haven't seen until this problem. also i can't seem to simplify the circuit into a single "line" if you know what i mean.
Likes rsalami
Or just write the KCL equations for the circuit. I would put ground at the middle right of the circuit, between the 3 resistors. For the open-circuit case, there is no current flowing in the middle branch (obviously).
Can you show us the KCL equations?
Incidentally, this is not an RC circuit because there are no capacitors.
When you do have to find the transient voltages and currents in a RC circuit in DC by using differential equations, you will then realize a new level of "difficult".
Finding voltages and currents in an RC circuit in AC has challenges as well, but is not as difficult as the dreaded DC transient RC circuits.
Both of these will be coming to you soon assuming you are in an engineering program.
A hint to solve the problem...there is ZERO current thru that middle branch as suggested above.
KCL?
AGGENGR said:
KCL?
Kirchoff's Current Law (KCL). I'm guessing by your response that you haven't covered that yet in class. It's a very easy and useful technique to learn -- maybe check it out at Wikipedia, and you will be ahead of the rest of your class! :-)
Ahh i see now. Thanks
