What Angles Reveal Second Order Bright Fringes in Diffraction?
The discussion centers on calculating the angles for second-order bright fringes in a diffraction grating problem. The user initially used the equation d sin(theta) = m(λ) but received feedback that their calculated sin(theta) value of 1.178 exceeds the possible range for sine, indicating no rational angle exists. It was suggested that the grating constant might be incorrectly stated as 10,000 lines per cm instead of the more typical 1,000 lines per cm. The user confirmed they had converted units correctly in their written work. The conclusion is that with such a fine grating, the second maximum does not appear.
Shahab Mirza
Hi,
1. Homework Statement
Q : A diffraction grating with 10000 lines per CM is illuminated by yellow light of wavelength 589 nm, At what angles is the 2nd order bright fringes seen ?
From my textbook , I got this equation , d sin theta = m (λ)
Ok so what I did was that I plugged values properly , i.e
sin theta = mλ/d
For second order , m=2 so,
= (2) (589 X 10nm) / (1/10000 X 1/ 100)
and the answer is 1.178 , but out teacher said that this number is larger than 1 and so sin theta does not represent any rational angle , so tell me that how to know that sin theta in this case "1.178" does not represent any rational number , please help me out with this , Thanks [/B]
What does 589x10 nm mean? You have to substitute the wavelength in meters.
The value you got for sin(theta) is correct, perhaps the grating constant is 1000/cm instead of 10000/cm. The grating constants are usually in the range of micrometers.
Your teacher is right, in case of such fine grating, the second maximum does not appear.
Thanks for reply Sir ,
Actually in real problem which I solved on a paper I wrote 1/10000 X 1/100 and converted it into right unit .
Thanks a lot for your kind reply .
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
