How Far Do Different Colors Spread in a Diffraction Grating Experiment?
The discussion revolves around calculating the distances of the first-order hydrogen spectral lines on a screen using a diffraction grating with 475 lines/mm, located 2.8m away. Participants emphasize the use of the equation dsin(theta) = n(lambda) and suggest converting units for accuracy. There is confusion regarding the application of the angle theta and the calculation of the slit separation. One user attempts to use the equation x = n(lambda)L/d but struggles with the correct values and units. The conversation highlights the need for clarity in calculations and unit conversions to arrive at the correct distances for the red, blue-green, and violet lines.
dlucia
Question: Light from a slit passes through a transmission diffraction grating of 475 lines/mm, which is located 2.8m from a screen. What are the distances on the screen (from the unscattered slit image) of the three birghtest (first-order, n=1) hydrogen lines for red 657nm, blue-green 486nm, and violet 434nm.
I do not even know where to begin to solve this equation. The help is much appreciated.
(please use the homework template in future)
what equations do you know that might be relevant?
dsin(theta)=n(lambda)
ok, now apply that equation to the figures in the question …
what do you get? :smile:
I don't know what to do with the theta, since it is not given. and would i say that 1/d=the 475 mm/lines?
and the final units needs to be in cm
Personally, I'd do all the calculations in m and then, if demanded, change the final answer to cm.
I have been trying everything under the sun and still can not get the answer right. i used the equation x=n(lambda)L/d
L=2.8m
Lambda= 657nm
d=(475 lines/mm)^-1
am I incorrect with that or no? Because the answer is still wrong for finding the distance between the slits.
show us your actual calculation and results :smile:
18K
21K
9K
