Diode - RC circuit differential equation
The discussion revolves around deriving the differential equation for a diode in an RC circuit, with a focus on using MATLAB for solving the equation and visualizing the results. Participants explore the mathematical formulation, coding issues, and debugging strategies related to the implementation of the solution.
  • Homework-related, Technical explanation, Mathematical reasoning, Experimental/applied
  • One participant expresses difficulty in deriving the differential equation and seeks confirmation on their approach using MATLAB.
  • Another participant suggests isolating the new output voltage value to facilitate calculations over a timestep.
  • Concerns are raised about the output voltage values being unexpectedly small, prompting discussions on debugging the MATLAB code.
  • Participants share their experiences with MATLAB and MathCad, indicating varying levels of familiarity with the software.
  • Suggestions are made to check the timestep size in relation to the input waveform period and to adjust the total time for simulations.
  • One participant revises their code but continues to encounter issues with the output voltage graph, indicating a need for further adjustments.
  • Recommendations are provided to print variable values during iterations to identify potential errors in the calculations.
  • After adjustments, one participant reports success in obtaining a working solution, indicating that the output voltage scale was manually adjusted for clarity.
Participants generally agree on the need for debugging and adjusting parameters in the MATLAB code, but there is no consensus on the exact cause of the initial issues or the best approach to resolve them.
Limitations include potential dependencies on specific assumptions regarding the circuit parameters and the accuracy of the numerical methods used in the MATLAB implementation. The discussion does not resolve all uncertainties related to the differential equation's derivation or the MATLAB coding process.
Dethoven
I'm having difficulty deriving the differential equation, this is what I have so far. In order to solve it, I will be using Matlab, and I'll be using the equation dy/dx ≈ (y(x + dx) - y(x))/dx. Is my derivation correct so far?
In picture.
If it's correct, do I just need to make DVout/dt the subject, then apply the approx. derivative equation to then calculate the values?
You're on the right path, but ffter you've made your substitution for the derivative you'll want to isolate the "new" value ##v_{out}(t + dt)## so that you can calculate the new ##v_{out}## from its current value over the timestep dt.
I've updated it as follows:
The problem I've had with this is that when I write a MATLAB program to solve it, and display it as a graph, it definitely doesn't seem correct. For some reason, the voltages are incredibly small, i.e. 2x10^-16.
Your final expression for ##v_{out}(t + dt)## looks fine. Must be something to do with how you are doing the integration in MATLAB. So you'll be looking at debugging that. Maybe running for just a few timesteps and printing out the various variable values will help.
I'm not very familiar with MATLAB, but I get reasonable results using the same expression in MathCad.
If I post the code, would you be able to see where I'm going wrong if possible? The MATLAB language is rather basic, or at least what I've wrote.
You can post the code (be sure to use code ... \code tags around it to preserve formatting). But you really should get some experience with debugging your own code.
I agree, I have tried debugging it although I honestly can't see what's wrong.
Code:
%Variables and constants
C = 0.001;
R = 10;
V0 = 2;
f = 50;
I = 0.000001;
dt = 0.01;
t = 0:dt:2;
Vin = V0 * sin(2*pi*f*t); %Input voltage
Vout(1) = 0; %Initial Vout
for n = 1:length(Vin) - 1,
    Vout(n + 1) = Vout(n) - ((Vout(n) * dt) / (R * C)) + ((I * dt / C) * (exp((Vin(n) - Vout(n) ) / 0.0259) - 1));
end
plot(t, Vin, 'k--', t, Vout, 'k')
ylim([0 2]); %Limits y-axis
xlabel('time');
ylabel('voltages');
Check your timestep size. How does it compare to the period of the input waveform? What's a reasonable total time to cover, say, two full periods?
I've now tidied it up, but the graph doesn't look promising. The Vin graph is fine, but the Vout isn't good at all, Vout does get quite large.
This is the new code:
Code:
C = 0.001;
R = 10;
V0 = 2;
f = 50;
I = 0.000001;
dt = 0.001;
t = 0:dt:0.08;
end
ylim([0 2.5]); %Limits y-axis
xlabel('time');
ylabel('voltages')
Here are the graphs:
Vin should be between + and - 2 Volts, so you'll want to adjust the y-axis for its plot.
I think that your dt should be even smaller to begin with. Try something like a hundred "samples" per cycle of the input.
I see that your output voltage scale looks rather large. You'll need to find out how that happened. Try printing out the terms of the equation for a few iterations and see where they're headed.
Thank you very much, it is working perfectly now. I manually adjusted the scale for Vout since it was very much of the graph. Once again, thank you for your help.
Glad I could help :smile:
  • · Replies 16 ·
  • · Replies 28 ·
  • · Replies 46 ·
11K
  • · Replies 16 ·
