Diodes - red & orange (light from one or both)
  • Thread starter Thread starter mstud
    Diodes
The discussion revolves around the design and functioning of light-emitting diodes (LEDs), specifically red and orange LEDs, in a circuit that allows for the emission of either color or a combination of both. Participants explore circuit configurations, voltage requirements, and the underlying physics of LED operation, including photon emission and energy considerations.
  • Homework-related
  • One participant seeks assistance in designing a circuit that allows for the independent or simultaneous operation of red and orange LEDs, questioning the necessary voltage and configuration.
  • Another participant suggests using two wires to supply current to either one or both LEDs, proposing the inclusion of a resistor to limit current.
  • There is a discussion about the potential simplicity of the problem, with some participants expressing skepticism about the ease of the solution.
  • One participant raises a related question about calculating the voltage required for an LED to emit photons of a specific energy, leading to further exploration of the relationship between charge, energy, and voltage.
  • Another participant explains the process of electron-hole recombination in the diode and its relation to photon emission, while also questioning how to quantify the number of recombinations needed for photon emission.
  • Suggestions are made for using push-button switches to control the LEDs and for considering more complex designs, such as using low voltage AC to power the diodes.
  • There is a proposal to connect diodes in parallel with one reversed to avoid the need for protection diodes, along with a caution about checking data sheets for safety margins regarding reverse voltage ratings.
  • Participants discuss the implications of forward voltage drops and safety margins in protecting LEDs from reverse voltage damage, with hypothetical examples provided for clarity.
Participants express a range of ideas and suggestions regarding circuit design and LED operation, with no clear consensus reached on the best approach or solution. Some participants agree on the feasibility of certain designs, while others raise concerns or propose alternative methods.
Participants note the importance of verifying specifications from data sheets and considering safety margins in their designs. There is also an acknowledgment of the complexity involved in calculating the necessary voltage for photon emission based on energy considerations.
This discussion may be useful for students studying electronics, particularly those working with LEDs, as well as individuals interested in circuit design and the physics of light emission in semiconductors.
mstud
Depending on which substances they're composed, light emitting diodes typically need 1.5 - 3 V in forward bias to give satisfactory light. You have two light emitting diodes, red and orange, you want to couple together in a capsule. You want to make a circuit where the capsule sends out red or orange light, or a mixture of these two. That is so that one or the other or both diodes send out light. Draw ciruits with the diodes and a proper power supply.
N/A. That is I must use Kirchoffs 2. law for the voltages, right?
I don't know exactly how to solve this.
The diodes need 1.5 - 3 V voltage. To make the different combinations (diode 1 sends out red light, diode 2 sends out orange light, or they both combine to give a red-orange light) I must vary series and parallell coupling right? Or shall all combinations be possible in the same circuit?
How shall these circuits be?
Could anybody give me some help here?
How many wires are you allowed to have emerging from the capsule?
I can't find there are any limitations on the number of wires from the capsule in this problem...
So you'll just bring out 2 wires and supply current to one or the other, or both? Place a resistor in series to limit the current. Also bring out a common wire.
Sounds too easy. Surely there is some catch? What year of school are you doing?
I think it sounds to easy too...The problem is from a book in "Physics & Technology" for the 12th year of school. (I'm in the 13th now, actually)
One more question from the same topic:
Problem: An LED emits photons with the energy of [itex]3.68 \cdot 10^{-19}[/itex] J and the wavelength 540 nm. What is the least voltage which must be applied to the diode for it to emit those photons?
My question: How to find voltage based on this information?
(The answer shall be 2.30 V)
Problem: An LED emits photons with the energy of [itex]3.68 \cdot {-19}[/itex] J and the wavelength 540 nm. What is the least voltage which must be applied to the diode for it to emit those photons?
Consider the process that creates the photon: a charge (how big?) falls through an electric potential difference. How much energy does it pick up in doing so? If it is that energy that is converted to light, you should have a relationship to exploit...
OK. thank you :)
Uh, hmm, not quite sure of my reasoning.
The charge comes from recombination of electrons and holes in the diode. Each of these have a charge of 6.242×10^{18} e= 1.602×10^{−19} C and -6.242 ×10^{18} e = -1.602×10^{−19} C, respectively. But how can I know how many does recombine for the diode to emit a photon? From the energy of the emitted photon, which is equal to the energy pisked up when the charge falls through the electric potential difference, right?
Thanks in advance if you would take time to check this ...
One electron --> one photon. You can assume that the hole is stationary (it's "attached" to an atom that's pinned in place in its crystal lattice), so that, essentially, only the electron is accelerating and picking up KE). After all, holes "move" when an electron jumps into it leaving a new vacancy where the electron came from.
Oh, yes, that's true!
Then it is: [itex]Voltage=\frac{W}{q}=\frac{3.68 \cdot 10^{-19} J}{1.602 \cdot 10^{-19} C}= 2.297 \approx 2.3 V[/itex]
Thanks again...
In which case, marks awarded might hinge on the quality of the design. So I'd say you consider providing 3 push-button switches: labelled RED, ORANGE, YELLOW
If you want to try something more ambitious, think about powering them with low voltage AC. This way you need only two wires out of the capsule. You supply half-wave DC (of one polarity or the other) to power a single diode, or full-wave to "simultaneously" power both. Employ silicon diodes inside the capsule to do the routing to each led.
Good suggestions :) Thanks a lot!
Maybe I'll choose the last and most fancy way...
Musing further, if diodes were soldered together in parallel (but one reversed) there would be no need for protection diodes, the forward voltage of one would limit the reverse voltage on the other. Needs just 2 LEDs and one resistor. Best to verify this from their data sheets, though, to make sure there is a margin for safety, as significant reverse current though a LED is likely to damage it.
Very good suggestion !
I think I liked this one best... Practically, it would not be difficult to set up. And the plan still will show that one have understood much of the properties of diodes. (I see why it is important to check for a safety margin, so that the reverse current does not damage the LED).
Thanks a lot!
I only wonder where you get all these possible designs from...
To explain margin of safety: suppose a bright yellow LEDs had a forward drop of 3.8 volts, and your cheap red LED has a reverse voltage rating of 3.6 volts, then the yellow LED would not protect the red one from exceeding its reverse voltage rating.
(I just invented those figures for the purpose of discussion, that forward drop is not typical of current visible-light LEDS.)
What the margin of safety would imply is that to protect the red LED from exceeding its reverse voltage rating, the forward drop of the LED has to be a little lower than 3.6 V e.g. 3.4 V or something (in this case), or am I mistaken here?
If that was the case, what about the other way, is it possible that still the red LED will protect the yellow one from exceeding its reverse voltage rating ?
Based on the analysis of your photon energy, I'd say you'll find that the shorter the wavelength coloured LEDs will have a higher forward voltage. So red LEDs have the lowest forward drop of all the visible colours, so would protect all colours. (I'd need to check the data sheets for the different colours, before going ahead and depending on this generalisation, though.)
9K
  • · Replies 39 ·
11K
