Dirac delta function / Gibbs entropy
The discussion centers on the treatment of the Dirac delta function in the context of the Gibbs entropy formula. The user is confused about why the term ln(δ(ε(p,x) - E)) is omitted in the entropy calculation, given that the Dirac delta function is zero except at a specific point. It is clarified that while the Dirac delta function is infinite at that point, the logarithm of the delta function leads to complications that are typically resolved by recognizing that the integral of the delta function over the entire phase space equals one. The conversation also touches on the microcanonical distribution, suggesting that a small energy uncertainty allows for a more manageable approach using a function that approximates the delta function. Ultimately, the treatment of the Dirac delta function in this context is a nuanced aspect of statistical mechanics that simplifies under integration.
Silversonic
This is an issue I'm having with understanding a section of maths rather than a coursework question. I have a stage of the density function on the full phase space ρ(p,x);
ρ(p,x) = \frac {1}{\Omega(E)} \delta (\epsilon(p,x) - E)
where \epsilon(p,x) is the Hamiltonian.
Then the logarithm of that is taken to obtain;
ln(ρ(p,x)) = -ln(\Omega (E)) + ln(\delta (\epsilon(p,x) - E))
And then both sides are multiplied by ρ(p,x) and integrated over the phase space
∫ρ(p,x)ln(ρ(p,x))dpdx = -ln(\Omega (E))∫ρ(p,x)dpdx + ln(\delta (\epsilon(p,x) - E))∫ρ(p,x)dpdx
The term ∫ρ(p,x)dpdx equals one clearly, and the term on the LHS stays as it is. And ln(\Omega (E)) = S (omitting the Boltzmann constant for the moment [S = S/k]).
However my textbook completely negates the ln(\delta (\epsilon(p,x) - E)) term, the dirac delta function. As if it goes to zero. Leaving us with;
S = -∫ρ(p,x)ln(ρ(p,x))dpdx
Why can we do this? Why is that term equal to zero? I understand the function of the dirac delta function, δ(x) is zero anywhere else except x = 0, where it is equal to infinity. The intergal of the dirac delta function over all space is equal to one. So why then does ln(\delta (\epsilon(p,x) - E)) equal zero? That makes little sense to me, where \epsilon(p,x) is not equal to zero, then we're logging the number zero, and when it's equal to E, we're logging infinity. Neither case makes much sense, so why can we omit it/ say it is equal to zero?
I'm not sure how to handle the dirac delta function here either.
Usually the microcanonical distribution is defined in such a way as to allow for a small uncertainty in the total energy E. So, instead of an energy surface in phase space, you deal with a very thin energy “slab” of thickness dE. Then the density of states would be ρ(p,x) = \frac {1}{\Omega(E,dE)} \Delta (p,x) where \Delta (p,x) has the value 1 if ##(p,x)## lies in the slab and 0 otherwise. ##\Omega(E,dE)## is the volume in phase space of the slab. So, \Delta (p,x) would take the place of the dirac delta function.
Now, ∫ρ(p,x)ln(ρ(p,x))dpdx should give you what you want. But this doesn't really answer your question of how to do it directly with the dirac-delta function.
