How Does Dirac Delta Substitution Relate to Helmholtz's Decomposition Theorem?
In summary, the equation $\delta(x-y)=-(4\pi)^{-1} \nabla^{2} \frac{1}{\vert x-y \vert}$ is correct, but it has to be understood properly. The notation \delta(x-y) is an abuse and the equation can be proved using the divergence theorem.
muzialis
166
Hi All,
I found (Wikipedia page on Helmotz's decomposition theorem) the follwoing equality, which puzzles me:
$$\delta(x-y) = - (4 \pi)^{-1} \nabla^{2} \frac{1}{\vert x - y \vert}$$
I am not sure I understand, the r.h.s seems to me a proper function. The page mentions this a sa position, not an approximation, can maybe anuvboy help?
Many thanks
The right hand side is a function which has a singularity when x=y. For fixed y, if you "apply the divergence theorem" (which depending on the exact statement that you use may or may not actually apply) to the right hand side you integrating over a ball you will see that you get 1 if your sphere contains y, and 0 if your sphere does not contain y, which is the inspiration for this (in particular, the right hand side functions exactly as the delta function when it's under an integral sign).
Office_shredder,
I clearly see your point. I am still puzzled by the notation, as the equality sign seems to me an abuse.
Thank you very much
Best Regards
The equation is correct, but it has to be understood properly, namely in the sense of distributions. The [itex]\delta[/itex] distribution is defined as a linear functional on an appropriate space of test functions (e.g., the [itex]C^{\infty}[/itex] functions with compact support or Schwartz's space of quickly falling [itex]C^{\infty}[/itex] functions) by
[tex]\int_{\mathbb{R}^3} \mathrm{d}^3 \vec{y} \delta^{(3)}(\vec{x}-\vec{y}) f(\vec{y})=f(\vec{x}).[/tex]
In this sense you have to read the equation. To prove it, you must show that for any test function
[tex]\int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x} f(\vec{y}) \left (-\Delta_{\vec{x}} \frac{1}{4 \pi |\vec{x}-\vec{y}|} \right )=f(\vec{x}),[/tex]
which is not entirely trivial.
The intuitive physicist's way to understand it is that
[tex]G(\vec{x},\vec{y})=\frac{1}{4 \pi |\vec{x}-\vec{y}|}[/tex]
is (read as function of [itex]\vec{x}[/itex]) the electric potential of a unit-point charge located at [itex]\vec{y}[/itex], fulfilling the equation (valid in Heaviside-Lorentz units)
[tex]\Delta_{\vec{x}} G(\vec{x},\vec{y})=-\rho(\vec{x})=-\delta^{(3)}(\vec{x}-\vec{y}).[/tex]
In other words, it's the Green's function of the differential operator [itex]-\Delta[/itex].
Office_shredder,
it looks like I have understood less than what I thought...
Your explanation made perfect sense until I tried a direct computation.
For simplicity in 1D, I fixed y = 1.
Then, if I understood, the indicated function should behave as a delta-distributuion under the integral sign.
As $$\int_{-\infty}^{\infty} \delta \mathrm{d}x = 1$$ the same should be expected for the mentioned function, which in 1D behaves as $$\frac{1}{(x-y)^{4}}$$ and is hence not even integrable.
I thought this might be a problem related to the 1D setting.
I tried in 2D then, using the divergence theorem now
$$\int_{V} \nabla^{2} \frac{1}{\vert x -y \vert} \mathrm{d}V = ..$$
and then I got lost...
Could you please possibly expand on your explanation?
thanks a lot, much appreciated
PS: I think I might be closer now...I just realized what was in front of me clearly, that the fraction is the Green's function for the operator nabla^2, am I right? Thanks a lot to all
1. What is Dirac Delta substitution?
Dirac Delta substitution, also known as the Dirac Delta function or the impulse function, is a mathematical tool used to model the behavior of point-like forces or impulses in a system. It is represented by the symbol δ and is defined as zero everywhere except at the origin, where it is infinite.
2. How is Dirac Delta substitution used in scientific research?
Dirac Delta substitution is commonly used in various fields of science and engineering, such as physics, mathematics, and signal processing. It is used to simplify mathematical equations and models, particularly in cases where point-like forces or impulses need to be accurately represented. It is also used in Fourier analysis and differential equations.
3. Can Dirac Delta substitution be visualized?
Since Dirac Delta substitution is defined as infinite at a single point, it cannot be graphed in the traditional sense. However, it can be visualized as a spike or impulse at the origin on a graph. It is also often represented as a thin, vertical line on a graph, with a height of infinity at the origin and a width of zero.
4. How is Dirac Delta substitution related to the Kronecker Delta?
Dirac Delta substitution and the Kronecker Delta are both mathematical functions that are zero everywhere except at a specific point. However, they differ in their domains and definitions. The Dirac Delta function is defined as continuous and infinite at the origin, while the Kronecker Delta is defined as discrete and equal to 1 at the origin and 0 everywhere else.
5. Are there any real-life applications of Dirac Delta substitution?
Yes, Dirac Delta substitution has many practical applications in science and engineering. It is used in the analysis of electrical circuits, control systems, and signal processing. It is also used to model the behavior of atoms and subatomic particles in quantum mechanics. Additionally, it has applications in probability theory and statistics, particularly in the field of stochastic processes.
  • General Math
  • Calculus
