Direct Integration vs. Green's Theorem
The discussion revolves around evaluating the integral of (x-y) over the region defined by the upper half of the unit circle using both direct integration and Green's theorem. There was initial confusion regarding the limits of integration, with a correction made to clarify that the region R should indeed be defined by the inequality x^2 + y^2 ≥ 1 for y ≥ 0. The direct integration resulted in an integral value of -2/3, which was confirmed after some back-and-forth about potential errors. The application of Green's theorem was discussed, emphasizing the conversion of a double integral into a line integral over the boundary of the region. The relevant partial derivatives were identified, leading to the correct formulation of the functions needed for the theorem.
wifi
Problem:
##\int_R (x-y)dx \ dy=-2/3 ## for ##R=\{(x,y):x^2+y^2 \geq 1; y \geq 0\}## by
a.) Direction integration,
b.) Green's theorem.
Attempt at a Solution:
I'm a little confused with part a. Wouldn't the region R be defined by all the points above the y-axis that lie on, in addition to above, the circle of radius 1 centered at the origin?
I'm confused on what the limits of integration would be for the integral ##\iint (x-y) dx \ dy##.
I'm sure that's a typo. It probably should be ##x^2+y^2 \le 1##.
So by direct integration I have,
\int_{-1}^{1} \int_{0}^{\sqrt{1-x^2}}(x-y) dy \ dx = 2/3 Is it supposed to be negative?
You made a mistake somewhere. It is -2/3 rather than +2/3.
Dang. My limits are correct, yes?
Also, how could I apply Green's theorem. I thought the idea was to change a line integral into a double integral, right?
EDIT: Never mind, it was an error on my part. Still not sure how to apply Green's theorem.
Well, you have a double integral. You want to change it into a line integral.
So it'd just be a line integral over the boundary of the region, correct?
Since Green's theorem in a plane is given by \iint_R (\frac{\partial F_2}{\partial x} - \frac{\partial F_1}{\partial y})dx \ dy \ =\oint_C (F_1 dx +F_2 dy)
for this specific problem we'd have ##\frac{\partial F_2}{\partial x}=x## and ##\frac{\partial F_1}{\partial y}=y##.
Thus, ##F_1=\frac{1}{2}y^2## and ##F_2=\frac{1}{2}x^2##. Right?
Looks good.
