'Direction' of Angular Momentum
The discussion centers on the direction of angular momentum for rotating objects, specifically when an object rotates anti-clockwise in a vertical plane. It clarifies that the direction of angular momentum is conventionally defined as pointing towards the observer, which can be confusing since it seems non-physical. This convention exists to simplify mathematical descriptions of rotations and to distinguish between different axes of rotation. The right-hand rule is highlighted as a useful tool in this context, connecting angular momentum to other physical concepts like magnetic fields. Overall, the use of vectors for angular quantities is deemed essential for clear mathematical communication.
frankhawes
Hello everyone!
I'm going to uni in October and I'm brushing up on my mechanics before I go.
I've just got to a bit that has confused me before and has confused me again now:
When you have a rotating object, say it is rotating in front of you in a vertical plane and it is rotating anti-clockwise then I think I'm correct in saying that the direction of the angular momentum would be towards you.
I don't understand this, as far as I am aware there is nothing physical coming towards me...
Is this is just convention? If it is then why has the convention arisen, I can't see the convenience in arbitrarily giving the angular momentum a direction.
Please can someone help me :)
Thanks in advance,
Frank
The axis of rotation is pointing at you. See angular velocity, which is also vector.
Yes.
To make the math more convenient.
How would you distinguish rotations around different axes, if angular momentum didn't have a direction?
A.T. said:
Then do some math, and try to find a more convenient convention.
Thanks for your quick reply.
I have my same confusions over angular velocity.
Do you have any suggestions about what 'math' I can try? I agree this is probably a good way of developing an intuition for the convention.
Thanks again,
Frank
frankhawes said:
I have my same confusions over angular velocity. Do you have any suggestions about what 'math' I can try?
Try to mathematically describe arbitrary rotations. How would you distinguish rotations around different axes, if angular velocity didn't have a direction?
Likes 1 person
Okay, Thank you.
Consider the alternative of describing an angular quantity, such as angular position, angular velocity, angular acceleration, angular inertia, or torque with something other than a vector, such as some type of plane. You'd have the complication of mathematically describing the plane and trying to perform math such as torque = angular inertia x angular acceleration. Using vectors to describe angular quantities eliminates this issue.
As mentioned above, the usage of right hand rule (so that counter clockwise rotation is a vector pointed towards you as opposed to away from you) is a convention, but it corresponds to some conventions used in electronics, such as positive or negative charge, the direction of a magnetic field, and it's relationship to charges moving perpendicular to the magnetic field.
Likes frankhawes
Thank you, this makes sense :)
