Direction of Maximum Change for Function f(x, y) = x^2y^3 + xy at Point (-1, 2)
  • Thread starter Thread starter Jennifer1990
    Derivatives
The discussion centers on finding the direction of maximum change for the function f(x, y) = x^2y^3 + xy at the point (-1, 2) and determining if there exists a direction where the rate of change equals 18. The gradient vector is calculated as ∇f(-1, 2) = -14i + 11j, leading to the directional derivative equation -14v1 + 11v2 = 18. The conclusion drawn is that since the magnitude of the gradient vector is less than 18, there is no direction in which the rate of change can equal 18.
  • Understanding of directional derivatives
  • Knowledge of gradient vectors
  • Familiarity with unit vectors and their components
  • Basic calculus concepts, particularly multivariable calculus
  • Study the properties of gradient vectors in multivariable calculus
  • Learn how to compute directional derivatives for various functions
  • Explore the relationship between the magnitude of the gradient and rates of change
  • Investigate the implications of unit vectors in directional derivatives
Students and educators in calculus, particularly those focusing on multivariable functions, as well as mathematicians interested in optimization and directional derivatives.
Jennifer1990
Let f(x, y) = x^2y^3 + xy.
Is there a direction at (-1; 2) in which the rate of change of f is equal to 18?
Justify your answer.
plugging this into the directional derivative formula, i get
18 = -v1 + 13v2, where v1 and v2 are the components of the vector in whose direction the rate of change is 18.
But i do not know where to go from here...
What do you know about the magnitude of the gradient vector at a point?
I don't see that the "magnitude of the gradient vector" has anything to do with this problem. I do not, however, see how Jennifer1990 got that result. The gradient of f(x,y)= x^2y^3+ xy is \nabla f(x,y)= (2xy^3+y)\vec{i}+ (3x^2y^2+ x)\vec{j} and so \nabla f(-1, 2)= (2(-1)(2)^3+ 2)\vec{i}+ (3(-1)^2(2)^+ (-1))\vec{j}= -14\vec{i}+ 5\vec{j}. So the directional derivative, in the directon of vector v_1\vec{i}+ v_2\vec{j}[/tex] is -14v_1+ 5v_2= 18. Now remember that you do not want v_1 and v_2 themselves, you just want the direction, the ratio between them. Another way to do this is to remember that a unit vector, in the direction at angle \theta to the x-axis, is given by cos(\theta)\vec{i}+ sin(\theta)\vec{j}. Solve -14 cos(\theta)+ 5 sin(\theta)= 18 for \theta.
Isn't the direction of the gradient vector the one in which the function changes most rapidly, where its magnitude is the value of this greatest rate of change? When i made my suggestion, what i was getting at was the fact that the magnitude of del f is less than 18, hence there is no direction in which the rate of change is 18. My apologies if this is not correct.
Danago's argument is correct, since in general \nablaw is the fastest increase of w and the magnitude of \nablaw is the maximum directional derivative in that direction. HallsofIvy's logic is correct as well but the attempt to solve for theta will come up short. Keep in mind that he did not compute the "j component = 5" correctly if you attempt to go forward with what he did.
Sorry Danago, that was just too clever for me!
Oh! The j component is 3(-1)^2(2)^2+ (-1)= 11. Thanks, chriscolose.
  • · Replies 24 ·
