Discover the Frequency of an Echo Using the Doppler Effect - Solved!
The problem involves the Doppler Effect, specifically calculating the frequency of an echo received by a bat that emits a sound pulse while flying towards a wall. The bat's speed and the emitted frequency are provided, and participants are exploring how to apply the Doppler Effect equations to find the frequency of the echo.
  • Participants discuss the initial frequency emitted by the bat and how it is perceived by the wall. There is an exploration of how to treat the wall as a source after reflection. Questions arise regarding the correct setup of equations and the implications of sound wave inversion upon reflection.
Several participants have provided guidance on setting up the equations correctly, with some clarifying the steps involved in calculating the frequency received by the wall and then by the bat. There is acknowledgment of mistakes made in calculations and a general sense of collaborative troubleshooting without a definitive resolution.
Participants are navigating through potential confusion regarding the application of the Doppler Effect equations, particularly in relation to the movement of the source and observer, as well as the effect of sound wave inversion upon reflection from a wall.
Dreams2Knight
[SOLVED] Doppler Effect?
A bat flying at 4.0 m/s emits a chirp at 20 kHz. If this sound pulse is reflected by a wall, what is the frequency of the echo received by the bat?
Not sure. Do I use the f(1)=f*[(v+/-observer velocity)/(v+/-source velocity)]
Not sure where to start. I seem to remember something about sound waves being returned inverted if they hit a wall. Does this factor in?
Hi Dreams2Knight,
As a first step, if the bat emits at a frequency of 20 kHz, what frequency does the wall receive?
After you have that, the reflection is handled by treating the wall as a source. What do you get?
alphysicist said:
Hi Dreams2Knight,
Hello,
Thank you for replying.
Source: Bat
Observer: Wall
For the first equation I have f(1)=20[345/(345-4)] which is 20.23460411 kHz
Source: Wall
Observer: Bat
For the second equation I have f(1)=20[(345+4)/345] which is 20.23188406 kHz
Are my equations correct? If so, does the second equation give me my answer, or do I have to do something else?
The bat emits sound at a frequency at 20 kHz, but the wall does not. After reflection from the wall, what frequency does the sound have? That number is the source frequency f on the right hand side. What do you get?
Ok, so if I understand correctly, I need to set my equation up like this:
20.234=f(2)*[(345+4)/345]. This gives me 20.00209.
I confused myself at this point because when I put the numbers into my calculator, I accidently subtracted 4 from 345 instead of adding. Doing that gave me the right answer of 20.46 kHz. I was confused because I thought if the source was still, you used V+V(observor) on top, yet subtracting gave me the right answer.
Then I remembered my teacher mentioning sound waves being inverted when they hit a wall. So, I took the reciprocal of (345+4)/345 and divided 20.234 by that and also got the right answer.
So, did I have my equation set up correctly as 20.234=f(2)*[(345+4)/345]? Was taking the reciprocal of (345+4)/345 also the correct thing to do?
No, not quite. It's giving close to the right answer, but I think the way it should be set up is:
step 1: frequency received by wall:
<br /> f = 20 \frac{345}{345 -4} = 20.2346<br />
step 2: frequency received by bat:
<br /> f = (20.2346) \frac{345 + 4}{345} = 20.469<br />
Your other ways get close to the answer because, for example 1+x is close to 1/(1-x) when x is small compared to one.
Ah, I see my mistake now. Thanks so much for your help. I really appreciate it.
  • · Replies 16 ·
