Distance after pushoff between two objects
  • Thread starter Thread starter spider3367
A 60 kg parent and a 12 kg child push off each other on an ice rink, with the child accelerating at 2.6 m/s² for 0.5 seconds. The parent experiences an equal and opposite force, resulting in an acceleration of -0.52 m/s². After the initial push, both objects move with constant velocities, which must be calculated from their accelerations during the push. The total distance between them at 3 seconds post-push involves accounting for the distance traveled during acceleration and the distance traveled at constant speed. Accurate calculations require determining their final speeds after the initial acceleration phase.
spider3367
A 60 kg parent and a 12 kg child meet at the center of an ice rink. They push off each other for .5 seconds. If the acceleration of the child is 2.6 m/s^2, then what is the distance between the parent and the child at 3 seconds after their push off?
F=ma
X=Xo +Vot + 1/2at^2
I know that the net force of the child is (12)(2.6)= 31.2 N. Using Newtons equal and opposite law, I know that the force of the parent must be -31.2 N. Then to find the acceleration of the parent, -31.2=(60)a which means a= -.52 m/s^2. From there I think you plug in each of of the acceleration with time 2.5 into the equation above to get each of their positions (X=0 + 0 + 1/2 at^2). with that I get about 6 meters difference and I know that is not the answers
Hi spider3367! :smile:
(try using the X2 tag just above the Reply box :wink:)
Yes, you've basically done it correctly, but you've not read the question properly! :rolleyes:
The acceleration is as given for .5 seconds, but after that, the acceleration is zero. :wink:
(also, you could have got .52 m/s2 simply by using good ol' Newton's first law … there's no external force, so the position of the center of mass will be stationary)
Try again! :smile:
So I'm still a little confused.
(2.6 m/s2)(.5^2)*1/2=.325
(.52m/s2)(.5^2)*1/2=.065
add them= .39 meters? That seems like it can't be right.
(please use the X2 tag just above the Reply box :wink:)
i] you could have added the 2.6 to the .52 to get the relative acceleration, abnd put that into the formula
ii] you still have another 2.5 seconds of constant speed to account for. :smile:
(and I'm going to bed :zzz:)​
Am I on the right track with this:
xtotal=[0+(2.6)(2.5)] + [0+(.52)(2.5)] + .39 meters (from calculated accelerations)
(just got up :zzz: …)
Nooo … you need the speed after 0.5 seconds.
