Distance and acceleration from a v(t) graph
34 replies · 3K views
gladidi
Summary:: Please tell me an example
Determine the distance traveled by the object between 0-7 s.
Determine the acceleration of the piece in the range of 0-4 s
Determine the acceleration of the piece in the range of 4-7 s.I've tried, but something I'm doing wrong. Could you clarify?
Welcome to PF.
You need to show us your work before we can help you with this. How is the velocity as a function of time related to the position and acceleration as a function of time? How can you use that to help you solve these questions?
Welcome to PF.
This is the work.
gladidi said:
This is the work.
No, that is the graph you are supposed to use to figure out those 3 questions.
Please answer this:
Please answer this:
I've tried to solve it with a chart, but the answers aren't going right
You didn't answer my questions. Until you do that, you will not get very far on problems like this one...
How is velocity defined in terms of position and time?
How is acceleration defined in terms of velocity and time?
gladidi said:
Summary::
What specifically did you try?
What approach with a chart did you try?
What were your answers
and how did you get them, specifically?
robphy said:
What specifically did you try?What approach with a chart did you try?
< 12/4
< 12/4
Ok, that's a start.
Why 12/4?
robphy said:
Ok, that's a start.
Why 12/4?
Speed change / time to change
robphy said:
Ok, that's a start.
Why 12/4?
Acceleration formula
That sounds like a slope.
What is the speed-change [although velocity-change is more correct], during the time-change?
What is the speed at t=0s?
What is the speed at t=4s?
What is the change in speed?
Speed at t=0s =0?
Speed at t=4s? =12?
haruspex said:
Not according to the graph.
It is 3?
haruspex said:
Yes.
finally i got this right..
How solve this? Determine the acceleration of the piece in the range of 4-7 s.
Same process. What was the increase in velocity in that interval?
4 and 7 have same speed 12?
Yes, so what was the increase in speed?
24?
gladidi said:
24?
If you are earning $20 an hour and that changes to $20 an hour, how much is your pay rise?
0...
haruspex said:
Right.
So what is the speed increase from t=4s to t=7s?
Answer is 0..
The last point is to calculate the distance traveled by objects.
it is said that should calculate the surface area
