How Far Does a Hamster Run in Its Wheel in One Night?
A hamster runs in its wheel for 2.7 hours each night, with a wheel radius of 6.8 cm and an average angular velocity of 3.0 radians per second. The conversion of the wheel's radius to meters is crucial, resulting in 0.068 m. The hamster's speed can be calculated using the relationship between angular velocity and linear distance. One rotation of the wheel takes approximately 0.157 seconds, but further calculations are needed to determine the total distance run. Applying the definition of a radian is essential for solving the problem accurately.
katie beisel
1. The problem statement, all variables and given/known
A hamster runs in its wheel for 2.7 hours every night. If the wheel has a 6.8 cm radius and its average angular velocity is 3.0 radians per second, how far does the hamster run in one night?
w= delta theta/change in time
6.8 cm x .001m/1 cm = .0068 m
2.7 hrs x 3600s/1 hr = 9720 s
c = 2pi(.0068m) = .0427 m
3.0 rad/s = delta theta / 9720 s
=29160
the correct answer is 2.0 x 10^3[/B]
Check your centimeter to meter conversion? Remember there are 100 cm per meter right.
oh whoops yeah
then its .068 m
im still not sure where to go from there
katie beisel said:
oh whoops yeah
then its .068 m
You've converted the radius of the wheel from centimeters to meters.
You know that the hamster spins the wheel at 3 rad/s. How fast is this for a wheel with a radius of 0.068 m?
You could use the definition of radian here to help you.
so
i got that one rotation takes .157 seconds but i still don't know where to go from there
katie beisel said:
so
You still haven't applied the definition of what a radian is to this problem.
