Distance role in simultaneity measurement
analyst5
Thanks for the answers on my previous thread, it made some sense, and if I'll reply if there's further misconception.
My new question is quite connected to the famous Andromeda paradox. So it's stated that the Andromeda is far away and moving towards the galaxy will cause the observer to have the distant future of Andromeda as his present, in his reference frame (of course future compared to what the stationary observer considers present). So my question is, if we consider a third observer, which is also heading towards Andromeda with the same velocity as the previously mentioned one, but is much more close to Andromeda than the other one, will he consider the same event that the previously one mentioned as his present or will it be also the future one, but one that happened before the event that the observer that is more distant considers present. To sum up, what role does distance to the event play in defining what happens relative to an observer, if they are both having the same velocity, but one is much closer to the event?
This is a sub-question of the first one, but is very connected with it. I know Lorentz Ether Theory is not relevant anymore, but I want to know the postulates to understand SR better. So LET basically says that every observer that is at rest with aether is in a position of privilegy, and that his 'view' is correct, his plane of simultaneity is the universal one. But how is this compatible with the first topic of my post? If two observers are mutually at rest, and of course at rest with aether, they still may have different distances to the objects moving, for example, towards them, therefore they won't consider the same events as their present. Of course, I mean this, if distance plays a role in differences what observers with the same velocity that isn't zero relative to an object consider to be their present. So what is then considered to be the priviliged frame or criteria for absolute simultaneity in LET? In a hypotethical scenario, since it's basically abandoned.
I appreciate your answers, cheers.
Observers at rest wrt each other agree on simultaneity. More precisely, simultaneity is unchanged by either spatial or temporal translations of an inertial coordinate chart.
So no matter what the distance they have from Andromeda in this case, if they are inertially moving towards it, they will agree what event is 'the present' (i hate to use this word in this context) for them?
On the original interpretation of the Andromeda Paradox, it is stated that distance plays a big role because the Andromeda is very far away from the Earth. So if we put an observer closer, but still in a position of motion towars the Andromeda, how come that doesn't change anything?
Distance magnifies the effect of the velocity difference. This will be apparent if you look at the Lorentz transform for time: ##t'={\gamma}(t-vx)##. For small values of ##v## ##\gamma## is very close to one so the difference between ##t## and ##t'## is small unless ##x## is enormous; for ##v=0## ##t'## is always equal to ##t## and there's no time difference regardless of the distance.
@Nugatory, could you please do a comparision using Lorentz transformations, on the concrete example of Andromeda, the comparision between an observer that is in space (much closer to Andromeda than the Earth) but is heading towards Andromeda with the same velocity as the Earth observer (which is moving) and the stationary Earth observer so I can notice how the temporal difference remains the same as in the case of the Earth observer that is at rest with Andromeda and the Earth observer which is moving towards Andromeda? Or anybody else please?
Your original question involved two inertial observers at rest with respect to one another. In this case if they Einstein synchronize their clocks initially they will remain synchronized forever and the two will always agree on simultaneity. Now you've changed it to any and all inertial observers who may or may not be at rest with respect to one another in which case it's obviously not true because an initial Einstein clock synchronization of two relatively moving inertial clocks will fail to keep them synchronized forever (time dilation).
Two observers at rest with each other (that are moving towards Andromeda) and one Earth observer that is at rest with Andromeda. That's the scenario. Now I need comparance between frames, the one that is closer to Andromeda and traveling towards it, and the Earth one which is at rest with Andromeda.
If the two observers are moving relative to one another, they will not get the same time values for distant events, and the difference will be magnified by distance.
If they are not moving relative to one another, they will see the same time value for all events, regardless of distance.
Note that the velocity relative to Andromeda is irrelevant, except to the extent that if one of them is moving relative to Andromeda and the other is not, then of course they must be moving relative to one another.
But in my scenario, the distance from Andromeda to the observer in space which is moving towards to it is much smaller than the distance from Andromeda to the Earth observer. How would the Lorentz Transformations look for those two observers? P.S. I've understood the truth behind the equations for observers which are mutually at rest.
If two inertial charts are at rest wrt each other then they will agree on simultaneity.
If two inertial charts are moving wrt each other then they will disagree on simultaneity. The degree of disagreement will depend on the distance between the two events being considered, not on the distance between the origins of the inertial charts.
You're welcome.
I gave you a couple of diagrams with some explanation like you asked me for. Did they resolve all your issues? Please don't just leave the thread hanging.
Here are a couple of diagrams, again, like you asked for, showing an example of your scenario. Earth is the thick blue line and Andromeda is the thick red line. I show a star exploding at 2.5 million years in the mutual Earth/Andromeda rest frame. Two observers are moving toward Andromeda at 22% of the speed of light shown in black and green. The dots show the Proper Times for each object/observer. The bottom dots are time zero and the top dots are time five million years. You have to count between them to see the times for the other dots.
The thin blue line represents a radar signal going from the Earth and the black observer at their time zero. It also represents a radar signal going from the green observer at his time of one million years. The return echo from the exploding star is shown as the thin red line. It is received by the green observer at his time of three million years, by the black observer at his time of four million years and by the Earth at its time of five million years:
Although the above diagram shows that the star exploded at 2.5 million years, Earth has no awareness of this until its time reaches 5 million years. It can use the radar signals as I describe in your other thread to establish that Andromeda was 2.5 million light-years away at the time of the exploding star and that it happened at Earth's Proper Time of 2.5 million years.
But the black and green observers establish the time and distance to the exploding star differently because they also assume that the radar signals take equal times to get to the star as the echoes take to get back. For example, black sends the radar at his time of zero and receives the echo at his time of 4 million years so he establishes that the star exploded at his time of 2 million years at a distance of 2 million light-years. Green sends his radar signal at his time of 1 million years and receives the echo at his time of 3 million years so he establishes that the star exploded at his time of 2 million years (same as black) at a distance of 1 million light-years.
Now I transform to the mutual rest frame of the black and green observers:
As you can see, all the same radar signals are sent and the echoes received identically according to each object's/observer's clock as in the first diagram but this one is what the black and green observers establish based on their mutual rest frame.
I think maybe your point of confusion is that you didn't realize that we assume that the clocks for the green observer are synchronized with the black observer so that in their mutual rest frame, their Proper Times match the Coordinate Times and that is why they consider the times of distant events to be identical. If we don't do that, we can't meaningfully talk about simultaneity issues.
The only difference between LET and SR is that LET, as you say, assumes that light propagates at c in only one Inertial Reference Frame (IRF). If you decide that the Earth/Andromeda mutual rest frame is that privileged IRF, then you would consider the Coordinate Times and Distances of the first diagram to be the absolute times and distances of the universe and the coordinate times and distances of the second diagram to be considered artificial times and distances that are only conveniences and don't represent reality (or whatever, I don't really know what a LET adherent would call the second diagram). But if the LET adherent decided that the mutual rest frame of the two observers was the privileged IRF, then they would switch the interpretations of the times and distances between the two diagrams.
analyst5;
Here is a comparative illustration of the different perceptions of observers E earth, S1 & S2 ships moving toward A Alpha Centauri at .4c and .8c. ( a case that would be possible within a lifetime).
In the E frame, each sends a light signal at the origin, that reflects from an object at A. The coordinates (x,t) for the event are E(4, 4), S1(2.62, 2.62), S2(1.33, 1.33).
The magenta lines are the geometric equivalent of t/gamma (t = round trip time) for each observer. The coordinates are calculated using the SR convention of c*t/2. As speed increases, the observers frame is scaled by 1/gamma.
In the S1 and S2 frames, the observer perceives the universe to be contracted, since A arrives earlier than expected according to their local clock.
The same phenomena apply regardless of distance.
https://www.physicsforums.com/attachments/66205
The travelers at the same rate all agree on what happened, where, and when. They also agree that Andromeda-reference-frame clocks are set wrong and that their synchronization errors grow with distance from Andromeda. So something happening at time t1 for one traveler, also happened at time t1 for all other travelers in the same reference frame. But they see that the Andromeda clocks at the different positions do not agree on those times. They report that the Andromeda reference frame is wrong and thinks that the same events happened earlier (by Andromeda clocks) the farther they are from Andromeda (toward the farther travelers to Andromeda) .
Only if they agree to agree, that is, if they have previously agreed on a coordinate system and if they have synchronized their clocks. It doesn't happen automatically. In my previous diagrams in post #12, I picked up the scenario in the Earth/Andromeda rest frame when the black traveler left Earth and I defined that event as the origin of both diagrams. I also assumed that the Proper Times on all three of those clocks was set to the Coordinate Time and I pointed out that the Proper Time on the green traveler was not set to the Coordinate Time of that IRF but rather to the Coordinate Time of the mutual rest frame of both travelers. However, I didn't say how that was done and as a matter of fact, as is often done in scenarios like this, we don't concern ourselves with how clocks get synchronized but there is a required process that must be performed to actually make it happen.
Here is another spacetime diagram that starts prior to the green traveler leaving Earth:
At the beginning of this diagram, it's trivial for the Earth and the two future travelers to synchronize their clocks because they are all inertial, colocated and at rest with each other. But as soon as the green traveler leaves Earth at 22%c his clock immediately goes out of sync with the Earth and the future black traveler. Later on, when the black traveler leaves Earth at 22%c, both travelers are at rest in a mutual Inertial Rest Frame (IRF), but their clocks are not synchronized, even though they are now ticking at the same rate. Here is a spacetime diagram depicting that mutual IRF:
If they wanted to get their clocks synchronized, they would either have to spend a few million years doing it (essentially engaging in radar measurements) or they would have had a prior agreement on how the green traveler would modify his clock to anticipate the black traveler's launch from Earth, in other words, calculate ahead of time how far off the green traveler's clock would be in the coordinate system of the black traveler when he left Earth.
So if we look at either of the above two diagrams and assume both travelers use the radar method to determine the time of the exploding star, the black traveler will establish that it happened at his time of 2 million years at a distance of 2 million light-years, but the green traveler will establish that it happened at his time of 2.1 million years (the average of 1.1 when the radar signal was sent and 3.1 when the radar echo was received) at a distance of 1 million light-years. So they won't agree on where and when the event happened unless they have previously agreed to establish a mutual coordinate system.
By the way, they could have agreed to use their original coordinate system where they synchronized their clocks with Earth and then they would agree that the event of the exploding star happened at the coordinates of 2.5 million years and 2.5 million light-years, just like the first diagram shows.
As I just said, they could have agreed to use their original Earth/Andromeda IRF and then they would not say that any Andromeda clocks are set wrong or have any synchronization errors at all.
Look, I just pointed out that the two travelers have a synchronization difference in their own mutual reference frame unless they proactively do something about it. Synchronization only has meaning when two clocks are inertial and at rest with each other so your assessment doesn't even apply.
This is a confusing statement. If you're talking about Coordinate Times, then something that happened at t1 in a particular coordinate system happened at t1 everywhere else in that coordinate system where the Coordinate Time was equal to t1, whether or not any traveler was present at any of those other places. But if you're talking about Proper Times, then it is not even true unless all the travelers happened to have synchronized their clocks together (assuming, of course, that "in the same reference frame" means "at rest in the same reference frame").
What Andromeda clocks? Aren't we considering Andromeda to have just one clock colocated with Andromeda, whatever that position might be?
Anyone who believes or promotes the idea that one reference frame is wrong just because it has different coordinates for the same event than another reference frame doesn't understand that there is no privileged (or better or unique) reference frame.
Furthermore, it sounds like you are saying that even in the mutual rest frame of the two travelers, the Coordinate Times for an event at Andromeda are different for the two travelers and that simply isn't true, is it?
If we are studying "simultanious" events at a distance, the first thing we should do is Einstein-synchronize all clocks in our inertial reference frame. We can hypothesize synchronized clocks in each reference frame and study the problem.
Andromeda is in an inertial reference frame and can Einstein-synchronize all the clocks in that reference frame. That is what I am talking about.
You are right, there is no privileged inertial reference frame. But clocks that are Einstein-synchronized in one inertial reference frame will only agree with Einstein-synchronized clocks in another reference frame at one point along a line of their relative motion. So people in one inertial reference frame will not agree that the Einstein-synchronized clocks in the other reference frame are properly synchronized. If they understand SR, this will not surprise them and they can easily calculate how much "error" there will be in the clocks at each position in the other reference frame.
The issue of simultaneous events at a distance according to an Inertial Reference Frame (IRF) has nothing to do with synchronized clocks. When you transform from one IRF to another, do you think someone has to synchronize or resynchronize any clocks? The whole point of Coordinate Time is that it is not associated with any clocks.
Of course it does. An inertial observer deems a distant event ##q## to be simultaneous with an event ##p## in his vicinity if and only if a clock in the vicinity of ##q## synchronized with the observer's clock reads the same time as the observer's clock at ##p##. Using this prescription the inertial observer can build a global time coordinate and from it a global inertial frame.
The whole point of having a lattice of synchronized clocks is to build a global coordinate time relative to an IRF in the first place. Global coordinate time relative to an IRF has no meaning without a lattice of synchronized clocks to begin with.
Likes 1 person
If there is a clock at the distant event and if it is inertial and if it is at rest with respect to the observer and if it has been previously synchronized with the observer's clock (by radar methods), then, of course, two events at those two clocks must read the same time on those two clocks in order for those two events to be considered simultaneous according to Einstein's convention.
But there doesn't need to be a clock at the distant event in order for the observer (who, of course, must have a clock) to establish such simultaneity. If that were true, then there is no point in discussing simultaneity at large distances where no clock has ever been such as at Andromeda and especially not one that is at rest with the two observers moving toward Andromeda.
Why did you ignore my question:
Taylor and Wheeler in Spacetime Physics (second edition) introduce the lattice of synchronized clocks on page 37 but on page 44 they point out that the lattice is imaginary and conceptual (as if they needed to point that out). The lattice is like training wheels, after you learn to ride, you get rid of them. That's an important step. We don't want to associate Coordinate Time (the basis of simultaneity) with a bunch of clocks pervading the universe.
FactChecker said:
The lattice of synchronized clocks is imaginary and conceptual. They may be dirt simple, but they are conceptually correct. If your statements do not agree with the lattice of clocks, that should raise a red flag that your statements are wrong. It is sometimes good to go back to basics.
My statements don't disagree with the lattice of clocks so there's no red flag in my case. The red flag is if someone claims that there must be a lattice of real clocks or even a single clock connected by a rigid rod between an observer and a distant event in order to establish simultaneity.
Can you answer my question:
You do realize in physics we work with theoretical constructions right? We don't actually hire a person to go out into space and place a clock at each point. Sorry but this isn't a rebuttal it's just a poor cop out.
Obviously it's imaginary. But how else do you think coordinate time relative to an IRF is defined? It doesn't just pop up out of the blue. We construct it from first principles using synchronized clocks. Both global distance functions and global time functions relative to an IRF are constructed operationally using synchronized clocks, radar sets, and a theodolite.
EDIT: I would really recommend reading "Relativity and Geometry"-Torretti. Foundations are important, especially if one wants to avoid semantics based arguments such as this.
FactChecker said:
I hypothesize Einstein-synchronized clocks in any reference frame, not necessarily inertial.
That won't work: Einstein clock synchronization only works for inertial clocks that are at rest relative to each other. Try it!
FactChecker said:
Even if that reference frame accelerates, the clocks will still agree with times, speed of light, and all other physical phenomena measured in that reference frame. They define the time in that reference frame.
If you can define an "accelerating frame" (a better term would be "coordinate chart") in which there is a family of observers all at rest relative to each other (a good example is Rindler coordinates in flat spacetime), then you can define a coordinate time using those observers, yes. But the clocks carried by these observers will not be synchronized: they will run at different rates (they will share the same surfaces of simultaneity in the Rindler case, if you define those surfaces the way they are defined in Rindler coordinates, but their clock rates will still differ). Also, the speed of light will not always be ##c## in such a frame.
This won't work actually. A simple yet famous counterexample is that of the family of observers atop a rotating disk. Observers neighboring one another can always Einstein synchronize their clocks but the synchronization fails to be transitive amongst this family for a very specific reason, so it doesn't carry to all observers atop the disk consistently (actually it won't even carry to all observers at the same radius). Because of this, the observers can't use Einstein synchronization to build a global time coordinate whose level sets are simultaneity surfaces for the entire family. The "very specific reason" is spelled out here: https://www.physicsforums.com/showthread.php?t=734070
I never thought about rotation. I'll have to look into that. It seems to me that it might still work with linear acceleration. The increasing lag in the forward clocks is how I visualize the lengths shrinking in the direction of accelerated motion (the front of an object lags due to it's clock drifting back and the rear starts to close in on it). It's simple-minded, I know, but it makes me happy.
Update: Ok. I looked at your reference. I think I'll just take your word for it and let it remain one of the mysteries of life.
It will so as long as you agree to use non-ideal clocks (clocks that don't read proper time) in order to account for what Peter mentioned directly above.
Well you don't have to take my word for it! In order not to derail this thread, you can if you wish start a new thread on this and the people here can explain in simple terms why it fails for the case of rotating frames. In fact if you know vector calculus then you can easily understand the geometric relationship between the failure of global Einstein synchronization and local circulation (curl) of tangent fields.
PeterDonis said:
But the clocks carried by these observers will not be synchronized: they will run at different rates.
I was counting on that. I would call them still synchronized if at any point the acceleration stopped and the clocks would automatically be Einstein-synchronized for the new IRF. So the clocks at the front would have to drift slower compared with the clocks toward the rear. Isn't that what would happen?
Please do not introduce non standard definitions.
Maybe you can help me. I hope my meaning is clear even if my assumption is false. Maybe there is no terminology because my assumption that they would retain their Einstein-synchronization is false. My assumption is this: Suppose clocks are initially Einstein-synchronized in an IRF. If that reference frame starts accelerating, the clocks will drift versus each other when seen from the original IRF. At any instant they will still have a correct Einstein-synchronization in the reference frame at its new velocity. I assume that the amount of drift will exactly match what would be required for them to still be Einstein-synchronized at the new velocity.
If this assumption is false, I would be interested in knowing that.
If this assumption is correct, I don't know what other terminology to use.
But they won't be. See below.
No. The clocks at the front will tick faster than the clocks at the rear. I strongly suggest that you take a detailed look at Rindler coordinates and the behavior of objects at rest in those coordinates.
Unfortunately you're mixing up all these different frames and it's only making things more hectic than they need to be. If you have two Einstein synchronized clocks at rest in an IRF and you Born rigidly accelerate them along the line separating them so that they remain at rest relative to one another then they will immediately become desynchronized as explained earlier by Peter. If you impart to the initially synchronized clocks the same proper acceleration along the line separating them then they will not be at rest relative to one another but rather will have a relative radial velocity so they will still become desynchronized except now it's because of kinematical time dilation.
Likes 1 person
  • #31
Born rigid acceleration is interesting, and what I was visualizing without questioning it. So you are saying that a Born rigidly accelerating frame can see its clocks getting out of Einstein-synchronization. Sad. Nothing is simple. I see that there is no substitute for adopting better tools to analyse these things.
  • #32
Well it's not so much of an issue in the case of Born rigid linear acceleration. So as long as we are willing to use non-ideal clocks, we can synchronize all the clocks permanently by using point-wise Einstein synchronization and build a global Einstein time for the Born rigidly accelerating frame. The real problem is when we considering Born rigid rotating frames. Here there is a fundamental obstruction preventing the use of point-wise Einstein synchronization to build a global Einstein time for the rotating frame i.e. one cannot achieve global synchronization by using point-wise Einstein synchronization when considering a family of corotating clocks, regardless of whether we use ideal or non-ideal clocks.
Thankfully the tools aren't sophisticated by any means, you could easily acquire them by working through standard textbooks like MTW.
Likes 1 person
  • #33
Sorry but you were the one that said:
WannabeNewton said:
An inertial observer deems a distant event ##q## [a star exploding on Andromeda] to be simultaneous with an event ##p## [a reading on his clock] in his vicinity if and only if a clock in the vicinity of ##q## [a star exploding on Andromeda] synchronized with the observer's clock reads the same time as the observer's clock at ##p##. Using this prescription the inertial observer can build a global time coordinate and from it a global inertial frame.
You don't have to use those first principles with multiple synchronized clocks and multiple radar sets--a single inertial observer can do it all with just his one clock (synchronized to nothing else), his one radar set and his one theodolite.
If you think this is just a semantics issue then you need to clarify the terms in dispute. I would rather show you how the two observers approaching Andromeda can establish the simultaneous events without any synchronized clocks.
I start with the last diagram from post #15 but I have changed the radar signals to focus in on just the ones sent out by the green observer. Keep in mind that he is continually sending out radar signals in both directions and receiving their echoes along with the images of the other objects/observers but I'm only showing the significant ones. Note that there are no synchronized clocks:
To recap what the green observer does after the scenario is over, he first looks in his log of radar sent/received times and observations of Andromeda that he saw a star explode on Andromeda at his time of 3.1 years and the radar echo that he received simultaneous with that observation was from a radar signal that was sent at 1.1 years. He averages these two numbers and establishes that the event of the star exploding was simultaneous with the event of his clock reading 2.1 years.
Then he looks in his log for the sent/received radar information related to the black observer that also averages to 2.1 years and he finds a signal that was also sent at 1.1 years and received at 3.1 years along with the image of the black's clock reading 2 years and so he establishes that the event of the black's clock reading 2 years was simultaneous with the first two simultaneous events.
Finally, he does the same thing for the Earth data and establishes the event of the Earth's clock reading 1.96 years as simultaneous with the previous three simultaneous events.
So there we have it, green established four events as being simultaneous in the Inertial Reference Frame (IRF) in which he is at rest, using his own clock as the coordinate time, even though there were no other synchronized clocks.
Now I want to repeat the whole process but this time focusing on the black observer who is also racing toward Andromeda. He is at rest in the same IRF as the green observer but since their clocks are not synchronized, he will use his clock for the coordinate time of the IRF:
He observes the star on Andromeda exploding at his time of 4 years which corresponds to a radar signal sent at 0 years so he establishes his time of 2 years as being simultaneous with the event of the star exploding. He also establishes the simultaneous events on Earth as 1.96 years and the green observer as 2.1 years.
If you compare the events that the green observer established as being simultaneous in his rest IRF with the star exploding to the events that the black observer established as being simultaneous in his IRF with the star exploding, you see that they are identical, even though they used different time coordinates based on their own unsynchronized clocks.
Next I want to show the same measurements in the mutual rest frame of the Earth/Andromeda IRF. We start with the green observer's measurements:
All of green's measurements and observations and establishments are the same as they were in his rest IRF.
And here is the same IRF showing black's measurements:
All of black's measurements and observations and establishments are the same as they were in his rest IRF.
  • #34
George, I feel like we're speaking past each other. I'm not disagreeing with anything you're saying; yes I agree that you don't need synchronized clocks and as always your diagrams are crystal clear in driving home the operational use of radar simultaneity. However what I am saying is that using light signals to establish simultaneity is equivalent to using light signals to synchronize distant clocks so saying they have nothing to do with each other antagonizes that equivalence, that's all; here and elsewhere the "lattice" of synchronized clocks are all conceptual. But whatever you start with, be it synchronized clocks or simultaneity, you need one or the other as a starting point before being able to construct a global time coordinate relative to an IRF (and more general frames as well)-this part still holds true. In other words the concept of a global time coordinate relative to an IRF depends on the establishment relative to the IRF of operational clock synchronization or the equivalent notion of operational simultaneity. This is all with regards to inertial observers of course. As soon as we talk about non-inertial observers the equivalence between clock synchronization and radar simultaneity is broken naturally.
  • #35
WBN recommending a philosophy book by a notorious philosopher.:eek: Shame, shame.
  • #36
George;
How do you explain the longevity of these observers?
  • #37
phyti said:
George;
Lorentz Transformation.
  • #38
Then why is there an argument? If your results and conclusions are identical, what is your complaint?
Who said these are real? The space travelers are not real and the clocks are not real.
  • #39
Because the lattice of clocks is another way of saying a specific coordinate chart. The OP asked about two separated observers moving at the same speed toward Andromeda. They don't need to be using the same coordinate chart even though they are at rest in the same Inertial Reference Frame. This is what DaleSpam pointed out in his usual inimitable and definitive way in post #2 and in post #11, that they don't have to be using the same inertial coordinate chart, in other words, they do not have to have synchronized clocks or applying the same lattice of clocks. Your first statement was:
But this would only be true if they were using the same inertial coordinate chart which means the same imaginary lattice of clocks. And the OP didn't ask about the two travelers agreeing on where or even when things at Andromeda happened, he only wanted to know about how two traveling observers at different distances would measure simultaneity. This does not require them to be at rest in the same inertial coordinate chart or agree on distances or times or have synchronized clocks, only that they will agree on the same set of events being simultaneous. And that's what I proceeded to demonstrate in my post #15.
It sure sounded like that's what you meant when you said:
But I'm glad everyone now agrees that that is not necessary.
  • #40
ghwellsjr said:
...In my previous diagrams in post #12, I picked up the scenario in the Earth/Andromeda rest frame when the black traveler left Earth and I defined that event as the origin of both diagrams. I also assumed that the Proper Times on all three of those clocks was set to the Coordinate Time and I pointed out that the Proper Time on the green traveler was not set to the Coordinate Time of that IRF but rather to the Coordinate Time of the mutual rest frame of both travelers. However, I didn't say how that was done and as a matter of fact, as is often done in scenarios like this, we don't concern ourselves with how clocks get synchronized but there is a required process that must be performed to actually make it happen.
Now I'm going to show how the green traveler can synchronize his clock to the black traveler's clock so that they can both use the same coordinate chart to determine the distances to the event of the exploding star on Andromeda.
NOTE: I just realized that I neglected to add the "million multiplier" to all the units in my comments in post #33. Consider it done.
We start with the second diagram shown in post #15:
The green observer is continually sending radar signals to the black observer and watching for their echoes as well as watching the black observer. As soon as he sees the black observer launch from Earth, he notes the time the corresponding echo was received (1.1 million years) and when it was sent (-0.9 million years). He takes the difference in those two times (1.1+0.9 = 2.0) and divides by 2 (2/2 = 1.0 million years) and establishes how far light travels in that amount of time (1 million light-years). He takes the average of the sent and received times (0.1 million years) and determines that he should set his clock so that it would have read the same as black's clock at that time. Since he has just determined that he is 1 million light-years from black when black's clock was at 0, then he changes his clock from 1.1 million years to 1.0 million years as shown in this diagram:
The green observer also adopts the black observer's position as being at zero, making his own be at 1 million light-years. The green observer continues to send and receive radar signals. Eventually, he sees the star explode at Andromeda and determines that it occurred at the Coordinate Time of 2 million years and at a Coordinate Location of 2 million light-years, just as the black observer determined in post #15.
  • #41
This is something that would already be in place, like time zones, for practical reasons.
A remote event anywhere beyond the local inertial frame occurs independently of local events (unless you are pinging an object there with em signals).
A clock at the remote event will with a high probability be running at a rate different from the local clock, and therefore its time will be meaningless. All you get are two local time values for emission and detection of the returning signal. Using the SR simultaneous convention, you assign the remote event cordinates (ct, t). You declare the remote event to be simultaneous with t. This is physics by decree. You in fact do not know precisely where or when the event occured.
  • #42
For the umpteenth time, this is equivalent to Einstein clock synchronization. There is no difference mathematically or conceptually between Einstein simultaneity and Einstein synchronization for inertial observers at rest with respect to one another. Only operationally do the two differ. Also, we're obviously talking about ideal clocks here. The only way for two ideal clocks at rest with respect to one another to tick at different rates is for the clocks to be non-inertial whereas we're discussing ideal inertial clocks at rest with respect to one another-in this case as already stated Einstein synchronization ##\Leftrightarrow## Einstein simultaneity trivially. It's almost a tautology.
  • #43
I'm not saying there is a difference.
The only way for two ideal clocks at rest with respect to one another to tick at different rates is for the clocks to be non-inertial whereas we're discussing ideal inertial clocks at rest with respect to one another-in this case as already stated Einstein synchron ization ##\Leftrightarrow## Einstein simultaneity trivially. It's almost a tautology.
If the remote ideal clock was in synch, it wouldn't remain so after a year of Earth orbit, so what's the point?
I'm just emphasizing/reminding the poster that simultaneity is analyzed using a convention based
on definitions and not physical facts that are not available.
How much significance is simultaneity worth?
