Distance travel given constant a
The discussion revolves around a physics problem involving a hot rod's acceleration from 0 to 60 km/h over a period of 5.4 seconds. Participants explore concepts related to average acceleration, distance traveled under constant acceleration, and the time required to cover a specific distance given that acceleration.
  • Participants discuss the calculation of average acceleration and the distance traveled using kinematic equations. There is an exploration of different formulas and their equivalences. Questions arise about the correct application of kinematic equations and the representation of variables for distance.
Some participants confirm the correctness of initial calculations for acceleration and distance. Others provide guidance on using kinematic equations and express uncertainty about variable definitions. Multiple interpretations of the equations and their rearrangements are being explored, with no explicit consensus reached on the final time calculation.
There is a noted confusion regarding variable representation for distance in different resources, and participants are attempting to reconcile these differences while solving the problem.
angelcase
A hot rod can accelerate from 0 to 60 km/h in 5.4 s.
(a) What is its average acceleration, in m/s2, during this time?
(b) How far will it travel during the 5.4 s, assuming its acceleration is constant?
(c) How much time would it require to go a distance of 0.32 km if its acceleration could be maintained at the value in (a)?
for a, first I did a unit conversion for the speed:
60(1000/3600)= 16.667m/s=v
a=delta v/ delta t
a=16.667/5.4=3.086m/s^2
for b:
d=V^2/2a
d=(16.667)^2/2(3.086)=45.006m
for c:
I converted .32km to 320m.
a=3.086m/s^2 since it is constant...but I don't know what equation to use to determine the time to travel the distance.
I tried the values 19.19 and 10.18, both were wrong.
(a) and (b) results are correct.
a=delta v/ delta t
If you put it like that it seems that 16.667 is dv and 5.4 is dt. You can do that because you can also say this: [tex]a_{m}=\frac{\Delta v}{\Delta t}[/tex] where [tex]\Delta[/tex] stands for increment, v for velocity and t for time. You can do this when the acceleration is constant.
For (c) just take the third kinematic equation.
Your formula in (b):
d=v^2 / (2a)
is equivalent to:
d=(a*t)^2 / (2a) = (a * t^2) / 2.
By the way, this I think is more commonly used.
Karmalo, what is the third kinematic equation?? I am horrible with physics and reading the book is doing no good...
[tex]X=X_{0}+V_{0}t+\frac{1}{2}at^{2}[/tex]
Have you ever used this one?
I don't know if I have...is x= to distance? In different books and sites they use different variable to represent distance, whether it be s, d or x.
if that is the case would I rearrange it to solve for t?
2(X-Xsub0)/(Vsub0+a)??
[tex]X[/tex] is the final position and [tex]X_{0}[/tex] is the initial position so you can say [tex]X-X_{0}[/tex] is the distance traveled.
You can work out the value of the time (t) from the equation.
Note: [tex]V_{0}[/tex] is the initial speed
I am not sure if I am doing this right.
I plugged in:
320-45-006=16.667t+ 1/2(3.086)t^2
for t I found it to be 3.886 then I added the 5.4sec already passed and got 9.286sec...does that sound correct, or am I not understanding.
So we have this: [tex]X=X_{0}+V_{0}t+\frac{1}{2}at^{2}[/tex]
We can pass [tex]X_{0}[/tex] to the left and we'd have [tex]X-X_{0}=V_{0}t+\frac{1}{2}at^{2}[/tex]
The distance is 320m so [tex]X-X_{0}=320[/tex], we also know the initial speed is 0 so [tex]V_{0}=0[/tex] and the acceleration, which is 3,086 m/s^2
Now we just have to replace this values and we get this: [tex]320=0+\frac{1}{2}\cdot3,086t^{2}[/tex]
[tex]t=\pm\sqrt{\frac{2\cdot320}{3,086}}[/tex]
As time cannot be negative: [tex]t=14,4(s)[/tex]
