What Are the Key Design Considerations for Sieve-Plate Columns in Distillation?
The discussion focuses on the design considerations for sieve-plate columns in distillation, referencing McCabe and Thiele's "Unit Operations of Chemical Engineering." Key points include the distinction between weirs and downcomers, the flow of vapor through perforated regions, and the pressure drop across plates due to friction loss and liquid hold-up. The conversation highlights the confusion surrounding hydraulic terms such as "liquid head" and "liquid hold-up," emphasizing the need for clarity in definitions and operational limits for sieve trays.
  • Understanding of sieve-plate column design principles
  • Familiarity with hydraulic concepts such as pressure drop and liquid hold-up
  • Knowledge of vapor-liquid equilibrium in distillation processes
  • Experience with McCabe and Thiele methods in chemical engineering
  • Research "liquid hold-up in distillation columns" for detailed definitions and implications
  • Study "pressure drop calculations in sieve-plate columns" to understand operational limits
  • Explore "hydraulic head concepts in chemical engineering" for clarity on various head types
  • Review "vapor-liquid equilibrium principles" to enhance understanding of distillation processes
Chemical engineers, process design specialists, and students studying distillation column operations will benefit from this discussion, particularly those seeking to clarify hydraulic concepts and improve their understanding of sieve-plate column design.
gfd43tg
I'm reading McCabe and Thiele's classic "Unit Operations of Chemical Engineering" section about the design of sieve-plate columns. Below is a figure showing a column. I have a few questions and some clarification would be great.
1. Isn't the weir for plate n-1 simply the downcomer for plane n? What is the distinction between a weir and a downcomer?
2. Is vapor from plane n going both through the perforated region (dashed lines), as well as through the underflow weir? Or strictly the perforated region.
3. Even without weeping, wouldn't at least some liquid go through those holes?
4. The pressure drop across a plate is from the friction loss in the holes and the pressure drop due to the hold-up of liquid on the plate. It is expressed as an equivalent head of liquid ##h_t = h_d + h_l## Since it seems to me the liquid is moving from the downcomer towards the weir, there is friction loss whether or not you have holes. Isn't that friction loss from the vapor coming up the holes? What is the pressure drop from hold-up of liquid on the plate? Is that like an accumulation of liquid on the plate until it reaches the height of the weir over the plate? You can see from the figure that the weir is slightly taller than the plate. I guess I don't understand hydraulically what liquid-hold up pressure drop is.
5. When it speaks of a pressure on a plate, shouldn't that depend on where on the plate you are talking? There should be a vertical pressure difference that allows vapor to flow from one plate through the holes into the next place, as well as horizontal pressure difference that allows the liquid to flow from the downcomer over to the weir.
6. In the operation limits for sieve trays section, it states
At low vapor velocities, the pressure drop is not great enough to prevent liquid from flowing down through some of the holes. This condition is called weeping and is more likely to occur if there is a slight gradient in the liquid head across the plate.
What is liquid head? I have always had a very muddied understanding of the term "head" used in hydraulics. There are velocity heads, pressure heads, liquid heads, every type of head conceivable and it confuses me.
Thanks for the sources, I particularly like the separation processes website. However, I am still confused about what the pressure drop due to liquid hold up means. I don't have a good idea in my head what the heck that means. Is liquid hold-up and liquid head the same thing?
Only if defined to be. Liquid hold-up could also be defined as "the total liquid held on a tray" (my experience). In this case, it would include all the liquid on a tray including in the downcomer and have units of volume.
  • · Replies 45 ·
