Divergence in spherical coordinates
7 replies · 5K views
billiards
I am stuck on this problem.
Use these equations:
[tex]\textbf{v}(\textbf{r}) = f(r)\textbf{r}[/tex]
[tex]\frac{\partial r}{\partial x} = \frac{x}{r}[/tex]
And the chain rule for differentiation, show that:
[tex](\nabla\cdot\textbf{v}) = 2f(r) + r\frac{df}{dr}[/tex]
(cylindrical coordinates)
Any help greatly appreciated, I will post my progres so far in a following post.
Cheers
So far I have tried to crack this by subbing in
in the bottom equation I get:
[tex](\nabla\cdot f(r)\textbf{r}) = 2f(r) + r\frac{df}{dr}[/tex]
But I think that if we write out the left hand side of the equation and separate out the differentials we get this:
[tex](\nabla\cdot f(r)\textbf{r}) = r_{x}\frac{\partial f(r)}{\partial x} + f(r)\frac{\partial r_{x}}{\partial x} + r_{y}\frac{\partial f(r)}{\partial y} + f(r)\frac{\partial r_{y}}{\partial y}[/tex]
Which I think reduces further to:
[tex](\nabla\cdot f(r)\textbf{r}) = 2f(r) + r_{x}\frac{\partial f(r)}{\partial x} + r_{y}\frac{\partial f(r)}{\partial y} = 2f(r) + r\frac{df}{dr}[/tex]
Which IF that is right (and it's a big IF) basically means that I'm left to prove that:
[tex]r\frac{df}{dr} = r_{x}\frac{\partial f(r)}{\partial x} + r_{y}\frac{\partial f(r)}{\partial y}[/tex]
That's where I'm stuck. I have a feeling that the total derivative is needed next and I am thinking along those lines, I still haven't used the chain rule yet so I think that will come into play in the total derivative context. It could well be that I've strayed off and am heading nowhere with this, which is why I need a bit of guidance.
Thanks
I assume you know, or can prove, that for scalar f and vector V in rectangular coordinates,
[tex]\nabla\cdot f\vec V = \nabla f \cdot \vec V + f(\nabla \cdot\vec V)[/tex]
Also, I assume the standard notation
[tex]\vec r = \langle x, y \rangle,\ r = |\vec r|[/tex]
Then by the first identity
[tex]\nabla\cdot f(r)\vec r = \nabla f(r) \cdot \vec r + f(r)(\nabla \cdot \vec r)[/tex]
The only place you need the chain rule is to calculate the first term on the right.
[Edit] Corrected typos.
Thank you for your reply.
If I understand you correctly then I have more or less followed your reasoning thus far.
I am stuck on the bit you mention in your last line, I am struggling to calculate the first term on the right.
The way I see it is that
[tex]\nabla f(r) \cdot \vec r = r_{x}\frac{\partial f(r)}{\partial x} + r_{y}\frac{\partial f(r)}{\partial y}[/tex]
Is that correct?
That's my last line in my earlier post. How do I invoke the chain rule here to get this into the form I am after?
Thanks
Is that correct?
Thanks
When you differentiate f(r) with respect to, for example, x, you get f'(r)rx. And do the dot product last.
Okay, I think I've got it now.
Use the chain rule:
[tex]\frac{\partial f(r)}{\partial x} = \frac{df}{dr}\times \frac{\partial r}{\partial x}[/tex]
And the result:
To get:
[tex]r\frac{df}{dr} = r_{x}\frac{df}{dr}\frac{x}{r} + r_{y}\frac{df}{dr}\frac{y}{r}[/tex]
Now rx=x. Use this result as well as the fact that in cylindrical coordinates r2 = x2+y2,and the term on the right reduces to the term on the left. Is this OK?
Cheers
LCKurtz said:
Yes, I think you have it figured out now.
Ahhh good. For some reason that one had me scratching my head for a while, but it seems quite simple now.
Cheers
