What is the explanation for the divergence of the vector function r^hat/r^2?
  • Thread starter Thread starter guyvsdcsniper
    Divergence
The discussion revolves around the divergence of the vector function \( \hat{r}/r^2 \), particularly in the context of vector calculus and electromagnetic theory. Participants are exploring the mathematical properties and implications of this divergence, especially in spherical coordinates.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are attempting to understand the calculation of divergence in spherical coordinates and questioning the treatment of \( 1/r^2 \) as a constant. There are discussions about the definitions and representations of divergence in different coordinate systems, as well as the implications of singularities at the origin.
The conversation is ongoing, with various participants providing insights and clarifications. Some have offered guidance on the divergence theorem and its application, while others are exploring the nuances of the Dirac delta function in relation to the divergence of the vector field.
Participants note that the divergence is zero where there is no source, and the discussion includes references to the behavior of the divergence at the origin, where spherical coordinates become singular. There is also mention of differing interpretations of the divergence's implications in the context of point sources.
guyvsdcsniper
Find the divergence of (1/r^2)r^hat.
Divergence Theorem.
Im having trouble understanding the divergence of this vector function. I am just getting lost at calculating the divergence. I get that 1/r^2 is a constant so you can pull it out, but where does r^2 x 1/r^2 come from?
##1/r^2## is certainly not a constant; remember that ##v_2## is a vector field on the whole of space (minus the origin), and ##r## varies depending on where you are!
You might not be aware that evaluating vector operators is not as straightforward when the basis vectors adapted to those coordinates depend on the position, as is the case for spherical coordinates. Ask if you'd like to know more, otherwise you can find lots of formulae here.
https://en.wikipedia.org/wiki/Del_in_cylindrical_and_spherical_coordinates#Del_formula
##\frac{1}{r^2}## is not a constant. You can't "pull it out".
The divergence operator has different representations in different coordinate systems.
In spherical the literal definition of divergence is
## \nabla \cdot \vec{A} = \frac{1}{r^2} \frac{\partial }{\partial r }\left( r^2 A_r\right) + \frac{1}{r \sin \theta} \frac{\partial }{\partial \theta} \left( A_{\theta} \sin \theta \right) + \frac{1}{r \sin \theta} \left(\frac{\partial A_{\phi}}{\partial \phi} \right)##
Your field has purely radial dependence so you can ignore the last two components.
I understand where the all the components come from. The proof is very lengthy and I tried working it out as well. It definitely one of things you just accept and use lol. Thanks for the help
I don’t know what proof you have seen, but it certainly does not need to be lengthy. By definition of divergence:
\oint_S \vec A\cdot d\vec S = \int_V \nabla\cdot \vec A \, dV
(which is also just the divergence theorem if you happened to define divergence differently). For the volume ##V##, pick a small coordinate block (sides being coordinate surfaces). The contribution from the radial component of ##\vec A## to the left-hand side is then
[A_r(r+dr) (r+dr)^2 - A_r(r) r^2]d\Omega
\simeq [\partial_r (r^2 A_r)] dr\, d\Omega
where ##d\Omega## is the solid angle element. Since the right-hand side is
(\nabla \cdot \vec A) dV = (\nabla \cdot \vec A) r^2 dr \, d\Omega
it immediately follows that the radial contribution to the divergence is
\frac 1{r^2} \partial_r (r^2 A_r).$$
The contributions from the other components are derived similarly.
@quittingthecult are you by chance encountering this for your upper level undergrad E&M course?
Perhaps
## \nabla \cdot \left( \frac{1}{r^2} \hat{r} \right) = 4 \pi \delta^3 \left( r \right)##
If so just use the divergence theorem and realize that the result is independent of size of the sphere. So if you shrink the sphere “infinitely” the integral needs to evaluate to the same thing, and same when you blow it up. Enter the Dirac-Delta.
It is a paradox of sorts because of you evaluate the divergence directly it will be 0, but if you evaluate the volume integral it’s ##4 /pi##. This is a really important paradox.
I don’t think it is that paradoxical to be honest. The form of the divergence is valid only where the coordinates are non-singular and spherical coordinates are singular at the origin so r=0 needs to be treated separately. That the Dirac delta appears is not very unintuitive either. The 1/r^2 field is the field of a point source and unsurprisingly divergence is zero where there is no source. The density for a point source is also formally infinite so the appearance of the delta distribution should also not come as a huge surprise as it describes exactly that - a finite source in a point.
Fair enough, not paradoxical, but it is an important nuance that needs to be addressed.
Sure, I agree. If I do not misremember, it is actually the first example I have of a delta distribution in my book already in the first chapter on vector analysis. Then just introduced to be the canonical density function for a point charge. It is then treated more formally in subsequent chapters.
That sounds interesting. I’ve been meaning to nab a copy. As soon as I get a little bit of extra money.
@Orodruin just read through your insight “birth of a textbook”…..beautiful hand written notes/pictures.
Yeah it was maybe a 12 minute video with some of the algebra omitted. I guess lengthy is subjective but after doing more research and your example I can see how it can be done faster.
Perhaps
Yea my book does state this to a T and really emphasizes on the paradox part but what Orodruin said about it being not that paradoxical makes sense
If you have access to it, section 1.5.2 of 'Introduction to Electrodynamics: Fourth Edition' by Griffiths has a good explanation.
Initially, I solved in Cartesian coordinates, which is a bit of a process. First, you can say that ##\vec{v}= \frac{\vec{r}}{r^3}= \frac{x \hat{x}+y \hat{y} +z \hat{z}}{(x^2+y^2+z^2)^{\frac{3}{2}}}##
We know that ##\nabla \cdot \vec{v}= \frac{\partial v_x}{\partial x} + \frac{\partial v_y}{\partial y} + \frac{\partial v_z}{\partial z}##
Lets try ##\frac{\partial v_x}{\partial x}## to start. You want to say that ## v_x= x(x^2+y^2+z^2)^{-\frac{3}{2}} = uv##, where ##u=x## and ##v= (x^2+y^2+z^2)^{-\frac{3}{2}}##. From here, use the product rule.
Note that you will need to use the chain rule to find that ##\frac{\partial v}{\partial x}= -3x(x^2+y^2+z^2)^{-\frac{5}{2}}##
Applying the product rule gives ##\frac{\partial v}{dx}= (x^2+y^2+z^2)^{-\frac{3}{2}} - 3x^2(x^2+y^2+z^2)^{-\frac{5}{2}}##
Similarly, ##\frac{\partial v}{dx}= (x^2+y^2+z^2)^{-\frac{3}{2}} - 3y^2(x^2+y^2+z^2)^{-\frac{5}{2}}## and
Adding these three values gives the divergence.
$$\nabla \cdot \vec{v}= \frac{3}{(x^2+y^2+z^2)^{-\frac{3}{2}}} - \frac{3(x^2+y^2+z^2)}{(x^2+y^2+z^2)^{-\frac{5}{2}}}$$
which simplifies down to zero. Note that ## (x^2+y^2+z^2)^{\frac{3}{2}}## is on the denominator.
In theory, this ends the problem. However, from graphing the function, we get the impression that the divergence should be positive. Note that, using the equation for the divergence in spherical coordinates, you also get zero. This is the method shown in the original post.
So lets have a look at the divergence theorem, which states that, if the surface you're integrating over acts as the boundary of the volume you're integrating over:
$$ \int (\nabla \cdot \vec{v})\, d\tau = \oint \vec v \cdot d \vec A$$
We can see from our solution for the divergence, that the solution to the left hand side should be zero.
So, to solve the right hand side, lets use spherical coordinates.
$$\oint \vec v \cdot d \vec A= \oint \frac{1}{R^2}\hat{r} \cdot (R^2 \sin\theta d \theta d \phi \hat{r})$$
Notice that ##R^2## cancels and just gives ##\int_0^{\pi} \sin\theta d \theta \int_0^{2\pi} d \phi = 4 \pi##
This is independent of R, implying that the entire contribution is from the origin. This could be why our divergence appears to be zero.
As mentioned earlier, in calculating our divergence we had ## (x^2+y^2+z^2)^{\frac{3}{2}}## on the denominator. If we are at the origin, this will lead to a division by zero error. Thus, we can see that the divergence is zero everywhere except the origin, where the entire contribution comes from. In order for our divergence theorem to be true, we need ## \int (\nabla \cdot \vec{v})\, d\tau = 4 \pi##.
This property of being zero everywhere except the origin is explained by the Dirac Delta distribution. In order for the divergence theorem to be correct, the divergence must be
$$(\nabla \cdot \vec{v}) = 4 \pi \delta^3(r)$$.
Hopefully this helps! Apologies if there are any errors in either working or formatting. The reasoning for this is, once again, found in section 1.5.2 of 'Introduction to Electrodynamics: Fourth Edition' by Griffiths (apart from the Cartesian working, so sorry if that's wrong). I think the main thing is to realise that the entire contribution to the divergence is from the origin, and then division by zero errors lead to an answer of zero, as well as some knowledge of the divergence theorem and the Dirac Delta distribution.
  • · Replies 17 ·
  • · Replies 16 ·
