Diverging Spherical Lens Proof
The discussion focuses on proving that a spherical diverging lens produces a virtual, upright, and reduced image of a real object using the thin-lens equation and magnification factor. The thin-lens equation, 1/p + 1/i = 1/f, is utilized, where 'p' is the object distance, 'i' is the image distance, and 'f' is the focal length. The focal length for a diverging lens is negative, leading to a negative image distance 'i', confirming that the image is virtual. The magnification factor, M = -i/p, is positive, indicating the image is upright, while further analysis shows that the magnitude of M is less than 1, proving the image is reduced.
  • Understanding of the thin-lens equation (1/p + 1/i = 1/f)
  • Knowledge of magnification factor (M = -i/p)
  • Familiarity with the properties of diverging lenses
  • Basic algebraic manipulation skills
  • Study the properties of concave lenses and their applications in optics
  • Explore the derivation of the magnification factor for different lens types
  • Learn about ray diagrams for diverging lenses to visualize image formation
  • Investigate real-world applications of diverging lenses in optical devices
Students studying optics, physics educators, and anyone interested in understanding lens behavior and image formation in optical systems.
emperrotta
Using the thin-lens equation and the magnification factor, show that for a spherical diverging
lens the image of a real object is always virtual, upright, and reduced?
Thin lens equation 1/p + 1/i = 1/f
p = distance of object from the lens
i = distance of image created by the lens from the lens
f = the focal length of the lens
magnification factor equation:
M = -(i/p)
M = magnification factor
I believe I have everything figured out except proving that the image will always be reduced. Here is what I have so far:
Starting with the thin lens equation:
1/p + 1/i = 1/f
Rearranging in order to solve for i:
i = \frac{pf}{p-f}
With a diverging lens, as light rays pass through the lens they are refracted away from the central axis of the lens. Thus, there is no focal point that the light rays refract towards. Rather, the backwards extensions of the rays extend towards a virtual focal point. Since the focal point of the lens is virtual, f in the equation above is negative. Giving f a negative value, the above equation becomes:
i = \frac{-pf}{p+f}
Since the object distance is considered to be always positive in these cases, then we know that the value for i will be negative. A negative value for i means the image is virtual.
Plugging a negative value for i into the magnification factor equation:
M = -(i/p)
we know M will be positive, which means the image is upright.
Now, here is where I get stuck. I don't know where to go from here in order to prove that the image will always be reduced. I know that a reduced image would mean that the magnitude of the magnification factor has is a fraction. In order to show that algebraically, I would have to show that i is always less than p. I just don't know how to do that, or maybe I am just looking at this the wrong way. Any help would be much appreciated.
M=-i/p = f/(f+p)<1
  • · Replies 16 ·
