Do fluid oscillation characteristics depend on the viscosity of a fluid?
This discussion focuses on the relationship between fluid oscillation characteristics and the viscosity of liquids, specifically in the context of fluid dynamics within a straw. The user conducted tests on fluids with viscosities ranging from 2 to 20 centipoise (cp) and observed significant differences in oscillation amplitude and damping factors. Key insights include the importance of understanding viscosity, fluid shear stress, and the dynamics of spring mass damper systems to establish mathematical relationships. The user successfully found valuable information on viscosity from Wikipedia, which aided in their research.
  • Understanding of fluid viscosity and its measurement (centipoise)
  • Knowledge of fluid shear stress and velocity gradient
  • Familiarity with spring mass damper systems and damping forces
  • Concepts of underdamped, critically damped, and overdamped systems
  • Research the mathematical relationship between viscosity and oscillation characteristics
  • Study the principles of fluid dynamics in confined spaces, such as straws
  • Explore advanced topics in damping systems and their applications in fluid mechanics
  • Investigate the effects of varying fluid viscosities on oscillation behavior in practical scenarios
Students, researchers, and professionals in fluid dynamics, mechanical engineering, and physics who are exploring the effects of viscosity on fluid behavior and oscillation characteristics.
tahskanaij
TL;DR
Are there any equations relating the viscosity of fluids to any kinematic variables (velocity, acceleration, kinetic energy)?
This is my first thread here, so let me know if I didn't adhere to a format i was to follow. I'm in the middle of a project depicting the change that an oscillation of fluid inside a drinking straw faces depending on the viscosity of the liquid.
For reference, this is exactly the same example I'm using: https://aapt.scitation.org/doi/abs/10.1119/1.5095945?journalCode=ajp
The papers included all did their tests at extremely low viscosities, ≈0.5 to 1 cp, so I couldn't seem to find any relation over there. Essentially, what I need to do is corellate the amplitude of my oscillation, as well as the damping factor to the viscosity of that liquid. I've done the testing and there is considerable difference between 2 and 20 cp. I can make a mathematical relationship easily, but in order to hypothesize first I need to depict the known relationships between viscosity and what it may impact.
Any help would be greatly appreciated.
First, study the definition of viscosity (search term). Wikipedia is a good place to start. Note how the fluid shear stress is proportional to the fluid velocity gradient. Then, in a situation such as fluid flowing through a straw, the resistance to flow must be proportional to fluid velocity.
Then study a spring mass damper system (search term). Note the assumption of damping force being proportional to velocity. Compare to the definition of viscosity. Note that the fluid in the straw has a mass, and that there is a force proportional to fluid displacement from the equilibrium position. Compare to the definition of a spring in a spring mass damper system.
For higher viscosity fluids, look into underdamped, critically damped, and overdamped systems.
Enjoy.
Enjoy.
Thank you so much! You directed me to the right place. I was surprised to find the solution to my problems on the Wikipedia page for viscosity itself. Next time onward, before starting a concept i'll read it's wiki first.
