Do ionic crystals have total electric dipole moment?
The discussion revolves around the total electric dipole moment of ionic crystals, exploring whether such crystals can possess a net dipole moment due to their lattice structure of alternating cations and anions. Participants examine both static and dynamic cases, as well as the implications of dipole moments in different dimensional arrangements of ionic lattices.
  • One participant suggests that ionic crystals should have a total dipole moment based on a one-dimensional model, calculating it as ##\frac{n}{2}ql##, where ##q## is charge and ##l## is the distance between ions.
  • Another participant counters that a large dipole moment does not necessarily imply a strong static electric field, referencing the relationship between dipole moment and electrostatic potential.
  • Concerns are raised about the magnitude of the dipole moment calculated, with one participant estimating it to be quite small and suggesting that the potential outside the crystal would tend to cancel out due to the overall neutrality of the ionic crystal.
  • Some participants argue that in a three-dimensional lattice, dipole moments from different rows would cancel each other out, leading to a net dipole moment that is negligible.
  • There is a discussion about the definition of local dipole moments and their relevance in electromagnetic dynamics, with differing opinions on their usefulness and how they should be defined in the context of ionic crystals.
  • References to ferroelectric materials are made, indicating that while some crystals can have a macroscopic electric moment, rocksalt does not belong to this category.
Participants express differing views on whether ionic crystals can have a total dipole moment, with some arguing for the possibility based on specific models and others asserting that the overall dipole moment is negligible or zero in three-dimensional arrangements. The discussion remains unresolved with multiple competing perspectives.
Participants highlight the importance of dimensionality in considering dipole moments and the limitations of one-dimensional models when applied to three-dimensional ionic crystals. There are also unresolved questions regarding the definition and significance of local dipole moments in this context.
taishizhiqiu
I have come up with a paradox: Ionic crystals, in which cations and anions form a lattice, seems to have total electric dipole moment!
For example, consider a one dimensional example:
In the above picture, a ##+## represents a cation and a ##-## represents an anion.
So in calculating the total magnetic dipole moment, with the definition ##P=\int x \rho (x) dx##, I pair the ions and each cation anion pair have a dipole moment ##-ql##, where ##q## is charge and ##l## is the distance between the cation and anion. Then the total dipole moment is ##\frac{n}{2}ql##!
I don't think ionic crystals can have total dipole moment because if so, salt will have electric field around it!
Can anybody explain this to me?
Here's some interesting data possibly related to your question.
Strong Forces at Work in Simple Table Salt
Intense electric fields alter electrons arrangement to produce light during NaCl crystallization
http://www.pnnl.gov/science/highlights/highlight.asp?id=1438
Crystalluminescence – the glow given off when a salt becomes a solid – was a critical “hint” to the team that the conventional wisdom underlying salt formation was incomplete. This led them to ask if intense electric fields actually occur in concentrated aqueous electrolytes and thus could be responsible for driving the electronic processes leading to the emission of blue light. The answer? Yes.
That's dynamics. What I concern is the static case.
Big dipole moment doesn't necessarily imply strong static electric field.
Dipole moment is p(r)=\int\limits_{V} \rho(r')(r-r')d^3r' while for example the solution to the electrostatic potential \phi(r)=\int\limits_{V} \rho(r')\frac{1}{|r-r'|}d^3r'. Or put even more simply, from gauss's law the electric field seems to depend on \int\limits_{V}\rho(r')d^3r' rather than the integral in the expression for p(r). So i guess you understand why although p(r) can be big, \phi(r) can be small.
I thought of something else, if we try to put some numbers in the formula \frac{n}{2}ql, n would be of the order of avogadro 10^24, q is of 10^(-19)Cb and l of order of 10^(-9)m so dipole moment would be of order of 10^(-4)Cb x m which seems pretty small to me. Also with the reasoning of my previous post i believe in points outside the ionic crystal (where we can make the approximation \frac{1}{|r-r'|}\approx\frac{1}{r} ) the potential \phi(r) of the n/2 dipoles will tend to cancel out because \phi(r)\approx \frac{1}{r}\int\limits_{V}\rho(r')d^3r'=0 because the total charge of an ionic crystal is zero.
So the total dipole moment is not zero? It seems so counter-intuitive to me.
Well hmm, if we take for example a cubic crystal one side of the cube will look like
I believe that's how the ionic cubic crystal is formed, that is, below above and next to an anion, always a cation is positioned.
So,we can see that the dipole moment of the first 2 lines is canceled (n/2 *q*l for the first row, n/2*q*(-l) for the second row) and thus the whole dipole moment of the side will be zero. The fault was that we were thinking in 1-D afterall.
Spontaneous electric fields in solid films
http://en.wikipedia.org/wiki/Spontelectrics
http://www.tandfonline.com/doi/abs/10.1080/0144235X.2013.767109#.VTFVjUt-_8s
http://astrochemistry.hw.ac.uk/docs/talks/JL_Astrosurf2013.pdf
Related topics
Apparently it you freeze water into a block of ice under the influence of an electric field, you will have a static crystalline structure with an electric dipole.
http://io9.com/5886809/something-strange-happens-when-you-add-electricity-to-an-icicle#
Electric charge separation during ice formation
http://pubs.acs.org/doi/abs/10.1021/j100244a027?journalCode=jpchax
Piezoelectricity / Rochelle salt
http://en.wikipedia.org/wiki/Piezoelectricity
http://en.wikipedia.org/wiki/Potassium_sodium_tartrate
I think that is the important point.
Yes a 1D lattice will have a dipole moment, of the order of 1 positive charge at one side and one negative charge at the other side (actually half of that, doesn't matter) - that is negligible for macroscopic objects. And if you add the second dimension, most of those dipole moments cancel for pairs of rows. You can still end up with a small net polarization from a few atoms, but most of the 1D lines cancel each other and the net effect is negligible.
Actually, I am thinking about the definition of local dipole moment. How to define it properly in ionic crystals?
I'm not sure if that is a useful quantity.
You can do something like weighting each atom by its distance with a Gaussian. The width of the Gaussian then defines how local your definition is.
I think local dipole moment is a basic quantity in electromagnetic dynamics. For example: ##D=\epsilon E + P##.
Only if you consider volumes so large that you don't have to care about atoms any more. As far as I understand you try to do that here.
The dipole moment (or polarization) for an infinite lattice is best studied using periodic boundary conditions. In such case the dipole moment is uncertain by a quantum (or defined modulo quantum). The topic is not trivial but an illuminating explanation can be found here:http://www.physics.rutgers.edu/~dhv/pubs/local_preprint/dv_fchap.pdf
There are crystals with a macroscopic electric moment, namely the so called ferroelectric substances. However, rocksalt does not belong to this class.
No, because polarisation is not simply the density of dipole moments, only in special cases.
That's the correct line of argument for e.g. rocksalt, but there are substances which behave like your one-dimensional example.
Then what is polarisation?
Read the article by Resta et al, useful nucleus was citing.
Namely, they (and others) use ##P(t)= \int_{-\infty}^t dt' j(t')##, where j is the current density.
  • · Replies 17 ·
11K
