Do Longitudinal Electric Waves Exist?
The discussion revolves around the existence of longitudinal electric waves in the context of dipole antennas, particularly focusing on the near field and the behavior of electric fields close to the antenna. Participants explore the implications of propagation delays and phase velocities in this region, questioning whether measurable radiation exists along the axis of a dipole antenna.
  • One participant questions whether measurable longitudinal electric waves exist close to a dipole antenna, suggesting that these would be characterized by a changing electric field with no accompanying magnetic field.
  • Another participant introduces the concept of the "near field" and references external material on dipole antennas to support their point.
  • There is a discussion about how to determine the velocity or propagation delay of the electric field at two on-axis measurement points, with one participant suggesting that this could be considered a form of wave.
  • Participants explore different types of velocities, including group velocity and phase velocity, and their relevance to the propagation of electric fields in the near field.
  • One participant provides a mathematical formulation of the electric field in relation to the dipole and discusses how phase velocity can differ from far field phase velocity based on proximity to the dipole.
  • Another participant shares a reference to a paper that supports their findings regarding near field phase velocity, indicating that it can exceed the speed of light.
Participants express differing views on the existence and characteristics of longitudinal electric waves and the implications of near field behavior. There is no consensus on whether these waves can be measured or how they relate to established concepts of wave propagation.
Participants note that the discussion involves complex mathematical relationships and assumptions about the behavior of electric fields in the near field, which may not be fully resolved. The implications of energy transmission and detection without disturbing the field are also highlighted as areas of uncertainty.
HarryWertM
This minimal-math question may have been answered in other thread(s) but they were too mathematical for me...
Feynman explains clearly, with minimal math, that electromagnetic dipole radiation on axis rapidly approaches zero with distance. But I am wondering if there is not measurable radiation on the axis of a dipole antenna if you are only a few wavelengths away. This would have to be a changing electric field with zero magnetic field - ie, longitudinal electric "waves".
Does exist?
Velocity is c?
Well, the first equation in the wikipedia paragraph you cite does indeed show a non-zero E field varying as a function of time and the dipole's frequency for theta=0:
So how does one tease out a velocity (or "propagation delay at two on-axis measurement sites")? And if so, would it not be logical to call these propagation-delayed E-field measurements as some kind of "wave"? Or does a lack of energy transmission imply impossibility of detection [without destroying the field]?
The wording "propagation delay" suggests that you are looking:
  • either for the group velocity, corresponding to a wavepacket in a narrow spectral band
  • or for the speed of propagation of a brutal wavefront, when a charge is suddenly created on the dipole
  • or for any situation in between
  • or even for the phase frequency, corresponding to the occurrence of maxima or minima of the wave at different places
The full discussion can be quite interresting.
In the second case, there would be an immediate influence at any distance, with the related question: is it possible to create such a charge jump on a dipole? I think this would lead to even wider discussions.
The group velocity would be an easier topic.
You could just analyse the supperposition of two waves with slightly different wavelengths.
The modulation (beats) of the total wave would propagate at the group velocity.
The phase velocity is even simpler, as it is w/k = c, the speed of light.
To be precise, "propagation delay" meant this:
Two on-axis (theta=0) measurement points are selected, one closer to the dipole at r_1 and one farther at r_2. The measured E field at (time=t_1, r=r_1) is E_1 and an almost equal [peak or trough] E_2 is measured at (time=t_2, r=r_2). Then "propagation delay" is t_2 - t_1.
This delay is dt = dr / vp where vp = w/k is the phase velocity.
The factor in front of the phase factor exp(...) doesn't play any role as far as the time when the signal peaks is involved.
A phase velocity of c would certainly be my wild guess, but can you offer any argument or website in support? Feynman said nothing about near field velocities. Only that the near field disappears.
Harry,
I was wrong!
The (near field) velocity you are looking for is not exactly the far field phase velocity.
You are considering the delay between two maxima in time at two different locations.
This is, by definition, the phase velocity.
Let us write the electric field in a simple form compatible with the dipole formula:
Er = A(r) exp(i(wt-kr))​
The phase is simply given by:
phase = p(r,t) = arg(Er) = arg(A(r)) + arg(exp(i(wt-kr))) = arg(A(r)) + (wt-kr)​
The term q(r) = arg(A(r)) is a funtion of the position, but not of the time.
Therefore we can write in a more compact way:
phase = q(r) + wt - kr​
To simplify, we can now consider two very close locations and see how a time delay can lead to the same phase:
p(r1,t1) = p(r2,t2)​
This leads to:
q(r1)-q(r2) - k(r1-r2) + w(t1-t2) = 0​
Since r1 and r2 are close, we can assume approximately that
q(r1)-q(r2) = arg(A(r1)/A(r2)) = k' (r1-r2) + neglible terms​
and therefore the condition becomes:
(k'-k)(r1-r2) + w(t1-t2) = 0​
or:
v = (r1-r2)/(t1-t2) = w/(k-k') = w/k * 1/(1-k'/k)​
From this, you can see that when the phase of A changes slowly,
the phase velocity is close to the far field phase velocity, since k'/k << 1 .
Conversly, when k'/k is not negligible, the phase velocity is different from the far field phase velocity.
It is also possible to go forward with the calculation.
Indeed from the dipole formula you get:
q(r1)-q(r2) = arg(1-i/(k.r1)) - arg(1-i/(k.r2))​
from this you can easily get (assuming r1 = r is close to r2):
k'/k = 1/(1+k²r²)​
or finally:
v = w/k * (1 + 1/(k²r²))​
This shows that the near field phase velocity is always larger than the far field phase velocity.
Or in other words, the near field phase velociy is larger than the "speed of light".
  • · Replies 41 ·
  • · Replies 21 ·
