Do strain gauges need calibration
  • Thread starter Thread starter jsmith613
    Calibration Strain
The discussion centers around whether strain gauges require calibration, exploring the implications of different types of gauges and their applications in quantitative and qualitative analysis. Participants examine factors that may affect measurement accuracy, including zero offsets and the strain gauge constant.
  • Some participants suggest that calibration necessity depends on the type of strain gauge used.
  • It is noted that ensuring zero offsets in measurements is crucial, as residual strain from various factors can affect readings.
  • Participants mention the strain gauge constant provided by manufacturers, highlighting that individual variations may necessitate checking this constant for improved accuracy, which could be considered a form of calibration.
  • One participant questions the intended use of the instrument, suggesting that calibration may not be necessary for casual use but is important for precise measurements.
  • Concerns are raised about gauges made from springs with hysteresis, indicating that stress application and release can lead to significant measurement discrepancies.
Participants express differing views on the necessity of calibration based on the type of gauge and its intended use, indicating that no consensus has been reached on this topic.
Limitations include potential variations in strain gauge constants and the influence of external factors on measurements, which remain unresolved in the discussion.
jsmith613
do strain gauges need calibration
The answer depends on the type of gauge.
But for all types of strain measurement, you need to make sure you don't have any "zero offsets" in the measurements. In other words, make sure you know what the gauges read for the condition that you want to call "zero strain". There is often some residual strain in the structure which you want to ignore, caused by things like its weight, geometrical tolerances when assembling it, thermal expansion, etc.
There is also the strain gauge constant, which is normally specified by the manufacturer.
However since he specifies for a type (not even a batch) there will be individual variations. So if you want better accuracy you need to check the constant. You can call this a calibration.
Are you using this instrument for any quantative or qualiatative anaylsists or is it just for indication purpose only? If your using it for playing aroudn with at home I'd say forgo getting it calibrated. But if you are using it for precise measurments, then your going to want to get it calibrated.
you should also watch out for gauges made out of springs with hysterical loops, because applying stress and then releasing it on the gauge will cause significant differentiations.
  • · Replies 77 ·
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 33 ·
