Do two magnets separated by a distance have potential energy relative
The discussion revolves around the concept of potential energy between two magnets separated by a distance. Participants explore the definitions, equations, and principles related to magnetic potential energy, as well as the educational context surrounding these topics.
  • Homework-related
  • Some participants question whether two magnets have potential energy relative to each other and seek clarification on the definition of potential energy.
  • There is mention of a lack of equations for calculating potential energy between magnets, with references to external resources for further information.
  • Some participants express confusion about why potential energy between magnets was not covered in their electricity and magnetism courses.
  • It is suggested that the potential energy of a system is related to the work needed to configure it, and that equations for the force between magnets and work should be available.
  • One participant notes that while they believe there is potential energy between magnets, they do not know how to calculate the force between them, which complicates their ability to calculate potential energy.
  • Participants discuss the complexity of permanent magnets compared to simpler geometries, suggesting that the magnetic dipole equation could be applicable under certain conditions.
  • There is a mention of empirical approaches to deriving equations for magnetic forces and potential energy, particularly in the context of materials engineering.
  • Some participants indicate that the treatment of permanent magnets in educational contexts is often qualitative rather than quantitative, leading to gaps in understanding.
Participants express varying levels of understanding and agreement regarding the existence and calculation of potential energy between magnets. There is no consensus on the specific equations or principles that should be applied, and multiple viewpoints on educational coverage of the topic are present.
Participants highlight limitations in their educational experiences, noting that certain fundamental concepts may not have been covered in their courses. There is also an acknowledgment of the complexity involved in calculating forces and potential energy for permanent magnets.
jaredvert
To each other? Repondez!
You should be able to figure that out - what is the definition of potential energy?
Kkkkkkk
Ok so here is something I don't understand. I've had electricity and magnetism course but I never learned of any such thingn. Why not?
You'll have to ask the people who taught the courses.
What level was the course taught at?
Is this stuff told of later on?
I suspect you will already have learned the law of conservation of energy, and the definition of potential energy.
Your course on magnetism should also have taught you about magnetic forces. If those bits are there, you should have been able to figure it out.
Yes but I know of no equation for potential energy between magnets.
... that does not answer the question I asked: what is the definition of potential energy?
You should have learned that the potential energy of a system is the amount of work needed to get it into that configuration.
You should have equations for the force between two magnets, and an equation for work, and so on.
The course may not have covered magnetic potential energy because the fundamentals had already been taught. After all, how much time will you have for the exam?
What level was the course taught at?I suspect you will already have learned the law of conservation of energy, and the definition of potential energy.
Unfortunately I am not sure how to calculate the force between two magnets, only between mag fields and wires
It's similar - permanent magnets are more complicated than bits of wire.
You are learning the situations for simple geometries so the maths is easier.
i.e. if you have two bar magnets length L which are separated by a distance D>>L, then you can use the magnetic dipole equation.
http://en.wikipedia.org/wiki/Force_between_magnets
But you can easily tell that there must be a "magnetic potential energy" because you have to do work to push two like poles close to each other. You can get two magnets and measure it.
Yeah I mean I was sure there was a pot energy between them but I didn't know the force between them so I couldn't calculate the pot energy between them. Are these equations created empirically?
Also I've read the whole giancoli physics based on calc 3 and I've never run into forces between permanent magnets.
That is usually the easiest way to do it in practice - but you can make approximations for simple geometries.
People who make magnets for a living need to be able to predict how strong-a magnet they'll get from a particular process.
I think this is a college level field of materials engineering.
You wouldn't - even though you have probably handled permanent magnets as part of practical demonstrations. At that level, and well into college, permanent magnets are mostly treated qualitatively.
You should have had a little bit on how permanent magnets work, at least in terms of "magnetic domains". There should also be a bit of maths about a magnetic dipole field ... this is the field due to a very small current loop. You can see the analogy between that and the field due to a permanent magnet.
  • · Replies 16 ·
15K
  • · Replies 25 ·
