Does a sling or a gun exert more initial force of the projectile?
A comparison between the initial force exerted by a sling and a gun reveals that while a .22 caliber bullet has greater kinetic energy (approximately 160 Joules) than a slingshot projectile (around 113 Joules), the concept of impulse, which measures momentum, differs. The stone from the sling, weighing about 2 ounces, has a calculated kinetic energy of 51 Joules, while a .22 CB round has slightly less at 45 Joules. The discussion highlights that kinetic energy scales with the square of speed, while momentum scales linearly, suggesting that the bullet has more energy but less momentum than the slower-moving sling stone. Thus, while a bullet exerts more kinetic energy, it does not necessarily require a greater impulse than a sling projectile. Understanding these distinctions is crucial for evaluating the forces involved in projectile motion.
Allenph
First of all this is probably the only time I will be on this forum.
At first this seems a no brainer. But I am a weekend survivalist and I made a sling that can sling rock a little more then 1" in diameter 120 yards at an angle of about 50-55 degrees. After some research the type of rock I am flinging is limestone which means it weighs about 2 ounces. Let's use say, a .22 caliber bullet. The bullet would weigh a little less then .09 ounces and go around 175 yards at 90 degrees. I have NO idea how to figure this out and am curious to know the answer. So does it take more force to shoot the rock or shoot a bullet?
It's kind of important to know an accurate weight for the rock you used if you want to calculate the impulse required to accelerate it. Looking up the weight of a similar small rock won't do.
Instead, let's find some figures from the internet to use. The muzzle energy of an average .22 LR pistol is about 160 Joules, according to the wikipedia entry below. This means that the bullet leaves the muzzle of the gun with 160 Joules of kinetic energy.
http://en.wikipedia.org/wiki/Muzzle_energy
In the following video, they claim that the world record kinetic energy for a handheld slingshot projectile is 113 Joules. This is less energy than a .22 bullet, and chances are you're firing them off with quite a bit less energy than the world record holder.
http://youtu.be/1v4TEX2erog
So, in short, a projectile from a handgun has more kinetic energy (and requires a greater impulse) than a projectile from a handheld slingshot.
Excellent thanks for answering my question
I learned the math. My stone has 51 joules and a .22 CB round has 10% less at 45 Joules.
More kinetic energy, yes. More impulse -- I don't think so.
The kinetic energy of a projectile scales as the square of its speed. The momentum of a projectile scales linearly with its speed. That means that a fast-travelling .22 slug has lots of kinetic energy but relatively little momentum compared to a slow-travelling sling stone.
"Impulse" is a measure of momentum, not energy.
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
