Does a solenoid get warm with inductance?
BenTHS
Hi,
I'm wondering if a solenoid is only hot by copper resistance or in addition with the inductance produced into the coil too ?
Another small question : in the sofware Femm there is a computing result parameter called "voltage drop"; does it means you need ( at least ) x volt to get the magnetic field or is it necessary to use much higher voltage ?
In Femm you indicate the diameter and kind of wire, the intensity or the number of turn but not the voltage of the power supply; I'm surprised ?Thanks by advance
Only resistance heats up with ##I^2R## losses. Pure L and puree C don't. But in real life and nothing is pure.
If the coil core is not of a ferromagnetic material-and no ferromagnetic material is in vicinity then no losses are expected. Since we are speaking about L and reactive power it is about a.c. current. In a.c. a magnetic core presents eddy-current and hysteresis losses. These losses could heat the core and from here the copper could be heated also. See-for instance:
Modeling Magnetic Core Loss for Sinusoidal Waveforms
http://www.dtic.mil/get-tr-doc/pdf?AD=ADA488218
I agree with you, in order to calculate the Fem one needs only L and I [Fem=LdI/dt].The voltage is present in the entire supplied circuit. However, the wire insulation has to be chosen according the presumable voltage.
