Does an airplane have to nose down in order to follow a curve?
  • Context: Undergrad
  • Thread starter Thread starter zanick
    Airplane Curve
The discussion centers on whether an airplane must adjust its nose downwards to follow the curvature of the Earth during flight. Participants explore the implications of aircraft dynamics, gravitational forces, and aerodynamics in relation to both level flight and the curvature of the Earth, as well as comparisons to other objects like the ISS and submarines.
  • One participant argues that no control input is needed for an airplane in level flight to follow the Earth's curvature, comparing it to a control line airplane that naturally follows a circular path.
  • Another participant suggests that a plane with a center of lift above its center of gravity can experience self-orienting torque, which may affect its ability to follow a curve without additional control inputs.
  • Concerns are raised about the stability of aircraft with varying center of gravity and lift center positions, with some asserting that a rearward center of gravity would still allow the aircraft to follow the Earth's curve without needing to nose down.
  • A participant references a physicist's claim that autopilot systems make slight adjustments to account for the curvature of the Earth, suggesting that the aircraft does not maintain altitude without these corrections.
  • There is a discussion about the ISS's rotation and whether it is influenced by initial launch conditions or requires corrective forces to maintain its orientation.
  • One participant questions the relevance of comparing the ISS to an airplane, suggesting that the dynamics of each are fundamentally different.
Participants express differing views on whether an airplane must nose down to follow the Earth's curvature, with no consensus reached. Some participants support the idea of necessary adjustments, while others argue against it, leading to an ongoing debate.
Participants reference various assumptions about atmospheric conditions, stability, and the mechanics of flight, indicating that the discussion is influenced by differing interpretations of aerodynamics and gravitational effects.
  • #121
sophiecentaur said:
Mea culpa too.
But any answer you came up with would have been just as irrelevant to the price of fish and most of the rest of this thread. The whole topic could be dealt with in a single paragraph, imo. :smile:
Well, that all depends on if you mean a paragraph of maths, or a paragraph of words.
No amount of words can answer this, IMHO.
ps. When Greg asks for upgrade ideas to the forum next time, please remind me to post that such problems should be sent to the "homework" section, where I'm pretty sure it would have died a quick, and merciful death.
  • #122
zanick said:
i think the question has morphed into two, maybe 3 , unintentionally.
1. does a properly trimmed and conditionally stable aircraft require additional control inputs to follow the Earth's curve at a set altitude and speed.
2. does this properly trimmed aircraft , also fly on a flat Earth with no changes to the control settings from the round earth.
2a. above but with the aircraft being conditionally unstable.
“Properly trimmed” includes everything that affects the (desired) flight characteristics of the plane: the speed and weight balance of the plane, the pressure and density of the air outside, the wind, etc. If the pilot notices the plane slowly gaining pitch and altitude, whether because of the earth’s curvature or some other reason, the trim can be corrected. In principle the same plane would then seem to be out of trim for flight in the exact same conditions except over a flat earth. That should answer 1 & 2. 2b shouldn’t change anything except that being out of trim is self-reinforcing.
  • #123
As mentioned in post #116, assume a normal plane with a center of mass slightly in front of the center of lift, and some up elevator (this is the elevator "trim") to generate aerodynamic downforce at the tail which compensates for the center of gravitational force being in front of the aerodynamic lift force. If "properly trimmed", the plane self corrects. If the plane pitches up, it slows down, reducing the downforce at the elevator, and the plane will pitch down and speed up. If the plane pitches down, it will speed up, increasing the downforce at the elevator, and the plane will pitch up and slow down. If due to curvature of the atmosphere about the earth, the plane travels into lower density air due to the curved atmosphere, the lift on the main wing decreases (and typically power from the engine also decreases), so the plane will tend to follow the curvature of the atmosphere around the Earth since the plane is trimmed to fly "level" at a certain speed and air density.
  • · Replies 34 ·
10K
  • · Replies 16 ·
  • · Replies 25 ·
