Does an object thrusted down from geosynchronous orbit land at the same spot?
  • Level: Undergrad
  • Thread starter Thread starter Eriance
    Orbit
Eriance
I a question regarding an object, that is originally in geosynchronous orbit, but then thrusted straight down. Will the object land directly on where it was hovering over while in the geosynchronous orbit? Or will it land off target because, as it falls, it's relative position to the Earth is no longer synchronized (earth rotates)? I'm having a hard time visualizing this.
This would require an huge amount of fuel (energy) to accomplish, but since you specifically stated "thrusted straight down", I'm assuming that the thrust is applied in the amount and direction to keep the descending satellite directly above the same point on Earth as the Earth rotates.
If instead a burst of thrust was applied perpendicular to the direction of gravity in order to slow down the satellite, it would enter an elliptical orbit. At least a second burst (again to decrease velocity) would be required to establish a lower circular orbit (at which point the satellite would orbit the Earth in less than 24 hours. Low Earth orbits take about 1 1/2 hours).
http://en.wikipedia.org/wiki/Hohmann_transfer_orbit
Ah thanks, for some reason, I thought with an initial thrust the satellite will just drop out of orbit and crash into the planet. Thanks for the feedback.
It could if so much velocity was removed that the resulting elliptical path was so narrow that the satellite would crash into the Earth instead of orbiting around it.
Let us assume that "geosynchronous" means a geostationary equatorial orbit in this case.
If "thrusted straight down" is taken to mean that the satellite fired its thrusters in a vertical direction then the satellite would surely miss the Earth -- or at least miss the point directly beneath it.
The satellite's orbit is about 22,000 miles above sea level. Add in the radius of the Earth and that's about 26,000 miles total. The circumference is two pi times that for something like 160,000 miles. It completes one orbit in just a little under 24 hours. So that's around 7,000 miles per hour.
A similar calculation shows that a point on the surface of the Earth at the equator is moving in a circular path at a little over 1,000 miles per hour.
If you fire your thusters, pushing the satellite straight down, it will retain its full orbital velocity in the horizontal direction. If you fire hard enough, it will crash into the earth. But that original horizontal velocity will mean that it will crash somewhere to the east of the point directly under where it started.
In the rotating frame of reference in which both Earth and satellite start out stationary, this is seen to be due to the Coriolis force.
