sshort75
- 7
- 0
If this question has an answer I didn't find it on the rest of the forums.
The discussion revolves around the concept of whether antimatter possesses negative mass. Participants explore theoretical implications, interpretations within relativistic quantum mechanics, and the relationship between mass and momentum in the context of antimatter. The conversation includes philosophical considerations and potential experimental observations related to gravitational and inertial mass.
Participants generally disagree on the nature of antimatter's mass, with multiple competing views presented. The discussion remains unresolved, with no consensus on whether antimatter can be considered to have negative mass or the implications of such a concept.
Some discussions reference the relationship between gravitational and inertial mass, and the potential for experimental measurements to clarify these concepts. There are also mentions of the mathematical frameworks used to describe mass and momentum, which may depend on specific definitions and assumptions.
haael said:Negative total mass (energy) is possible, but it is perfectly equivalent to positive mass with reversed momentum direction.
This isn't correct. Yes you can flip the signs of any or all of the variables that appear squared in that equality without violating the equality, but you will run into a bunch of problems with such things as conservation of momentum in particle collsions and Newtonian gravity (as Jesse already mentioned).haael said:Total mass and momentum 3-vector together form a 4-vector called 4-momentum. Total mass is its time component. Rest mass is its length. Of course this 4-vector lives in Minkowski spacetime, so total mass and rest mass are related by a known equation:
[tex]m_t = m_0 / \sqrt{1 - v^2/c^2}[/tex]
In natural units ([tex]c = 1[/tex]), the rest mass can be expressed as a length of 4-momentum:
[tex]m_0^2 = m_t^2 - p_x^2 - p_y^2 - p_z^2[/tex]
Consider a particle with some positive total mass and some momentum. This particle would have some rest mass and it would travel by some trajectory.
Now consider a particle with the mass and momentum reversed, i.e. negative, but otherwise the same that the previous particle. This second thingie would have the same rest mass and the same trajectory.
There is. A positron is exactly like an electron but with a positive charge instead of a negative charge. In particular, they have exactly the same mass.sshort75 said:Thankyou very much for the answers I should of phrased my question better I was wondering if antimatter had a weight of less than zero. I knew that it was magnetically attracted to matter because of the charge but I did not know if gravity repulsed it. It is my understanding by researching the topic further that there is no conclusive evidence one war or the other.
haael said:Philosophically, negative total mass describes particles that move backwards in time.
