Mentor
- 23,902
- 11,357
This and most of the "incorrect assumptions" you listed above mix a concept with a model:klimatos said:Take a barometer out of its case during a windstorm and watch how the needle moves wildly. Do you think that this truly represents the "weight of the overlying air"?
While a certain formula may require such a simplifying assumption (I don't think it is correct to call them "incorrect assumptions"...but then I am an engineer...), the concept is unaffected by variations in temperature.The barometric formula relating pressure to the weight of the overlying air is invalid in many respects.
If the barometer is measuring velocity pressure, then it isn't just measuring atmospheric pressure. That's not a flaw in the description of "atmospheric pressure", it's a flaw in our ability to measure it.When the wind blows across a building with open windows, barometers in the different rooms will show different pressures. And these pressures will be different from that registered by a barometer in the basket of a nearby drifting balloon at the same elevation.
Don't let the complexities of a moving atmosphere distract you from the reality that whether you model it as a pile of solid balls or a bunch of bouncing balls, the pressure is the same as long as you have the same number/weight of balls.
The conic section issue is interesting, though. I've never heard it and it sounds reasonable, but how big of a difference does it really make? We're not talking about a very large distance, since most of the atmosphere is packed close to the earth. Similar issue with g. I guess if I were being pedantic with the conic section one though, I'd say that saying "above" implies it must be conic/pyramidal, though I do admit I've never thought of it.
