Homework Helper
- 1,635
- TL;DR
- Is buoyancy still applicable in the case that surface of the body is not fully covered with fluids ? By buoyancy I would say is buoyant force = weight of displaced fluid .
I am discussing with friends whether concept of buoyancy is applicable even if the full surface of body is not covered by fluid(s).
As an example a clay ball is dropping in the pool water. Buoyancy is working on the ball. Then it reaches the pool flat and sticks with it to make a mountain shape. Does buoyancy still work on the clay mountain though upward water pressure does not work on its bottom surface ? Without the bottom upward pressure is the mountain is pressed by water pressure than when it was dropping in the water ?
I am skeptical to apply buoyancy to such a not-full-surface is covered by water case. We should rely on simple area integration of pressure to get force on the body. Your teaching will be appreciated.
EDIT By buoyancy I would say is buoyant force = weight of displaced fluid .
