Homework Helper
- 3,448
- 3,799
Devin-M said:@collinsmark can explain better than me but basically, [...]
@Devin-M, Sorry, I haven't been following this thread until now. But yes, I agree that ideally, if things are kept simple, I would expect the total ADU count of the double-slit should be pretty close to twice that of the single slit, all else being the same, if you were to add up all the (red) pixel values across a single line in each pattern. That's of course after dark frame subtraction. It's also assuming that your Nikon D800 isn't trying to modify the results in-camera.
Here's a few tips to help make sure your camera is not inadvertently messing up the results:
- If possible, store the images in RAW (NEF) format. When converting the Raw (NEF) file to some easily readable format, don't apply a white-balance, or if you have to, apply a neutral white balance (e.g., direct sunlight).
- If your workflow won't work with storing the data in RAW (NEF) format, then store the files in TIFF format. But don't store data as JPEGs.
- Do not use "Auto" white balance. Set it to something like "Direct sunlight," but the important thing is to make sure it's not set to auto.
- The Nikon D800 has selectable "Image Enhancements." Make sure your "Set Picture Control" option is set to "Neutral." See page 163 of your Nikon D800 manual for details.
- The Nikon D800 supports something called "Active D-Lighting." Make sure this is turned off. See page 174 of the manual for details.
- The Nikon D800 supports something called "Auto ISO Sensitivity Control." Make sure this is turned off. See page 111 of the manual for details.
- For that matter, try to make sure nothing is "auto," if you can think of anything else not mentioned here. Everything should be set to manual.
There's a lot of variables in what you're trying to do. A lot of stuff can go wrong, causing misleading results. So the above advice might serve as just a start.
