- 24,488
- 15,060
Yes, but then it's irrelevant for science. Science aims at the simplest models to understand what's observed in nature. We don't need the infamous angle's on a pin's heads! QT is complicated enough without any esoterics!
Lord Jestocost said:As a physicist, I would say: It seems that the decoherence program might be based on a simple circular reasoning fallacy.
vanhees71 said:Yes, but then it's irrelevant for science. Science aims at the simplest models to understand what's observed in nature. We don't need the infamous angle's on a pin's heads! QT is complicated enough without any esoterics!
vanhees71 said:BTW: The assumption that the state of macroscopic systems on the relevant level of accuracy (or resolution) is "decohered" is a simple observational fact. It's the reason, why classical (Newtonian or relativistic doesn't matter here) physics works so astonishingly well in a wide realm of everyday phenomena.
bhobba said:Of course.
Any interpretation in accord with the formalism,.even those some consider weird - like consciousness causes collapse - is scientifically valid.
What me and Vanhees try to stress is there is no need to go down paths like that - but if you want to of course you can. QM when viewed using minimalist interpretations like the Ensemble is much more 'common sense' and less weird than some try to present it.
Thanks
Bill
Lord Jestocost said:Some commenters here on PhysicsForums don’t seem to grasp that their “interpretations” merely reflect their “feelings” of what “relality” “ought to be”. In case you need your "ensemble interpretation", that's o.k.. But, please, be aware that's your personal "feeling" of what "ought to be out there".
You don't need any quantum mechanics for that. Ordinary classical wave theory will let you calculate how the interference pattern varies as the separation between the slits (and their width, which you didn't mention but is just as important) varies.DarioC said:Very well put itfitmewellputtoo. Somewhere in the forum I would like to post a question about the affect of the distance between the slits in the double slit experiment when using actual physical slits. I suspect there is some information to be found there. Likely already done, but I have not seen the info/results/etc.
PeterDonis said:The answer to all three of your questions is "yes, correct".
... the video camera recording was actually in a superposition and had not yet collapsed.
A better response to this kind of claim (i.e., a claim that only human consciousness can collapse the wavefunction, etc.) is that, since it is inherently untestable (I've just explained how it can explain away any possible test result you can imagine), it's not a scientific claim.
LOL. I don't have such qualifications. I am just a layman, as per my moniker, who wants to accurately understand what modern science says. Thanks for trying to promote me though.Johan0001 said:Science Advisor Gold Member laymanB said
Johan0001 said:2. If we turn one of the polarizers by 1 degree and repeat the experiment ?
How would the interference pattern change , on the detection screen.
3. If we continued to change the polarize by 1 degree , until the angle between the polarizers were 45 degrees.
How would the pattern then look.
4 Finally if we get to PERPENDICULAR polarizers we would get the 2 distinct ''collapsed" pattern.
My actual question , is , at what point can we say that the 'knowing which way' the photon went through , caused "collapse".
If indeed such a physical phenomenon of ''collapse'' really exists?
I understand that the angle between the polarizers determine the probability outcome of the results , but where would , if any "collapse"
fit into this setup, if any?
Jon Richfield said:At which point does observer A (human or artificial, organic or inorganic, conscious or otherwise, as long as it records relevant evidence) say that observer B (human or artificial, organic or inorganic, conscious or otherwise, as long as it records relevant evidence etc.) has collapsed all relevant wave functions, including her/s own?
You don't seem to realize that you are yourself smuggling unscientific misconception into your meta analyse of the meta analyse of QM.Lord Jestocost said:When going beyond this by “smuggling in” classical ideas and conceptions, one begins to produce pseudo-science which is at the end based on personal psychological prédispositions (implicit assumptions).
Actually, I have learned a lot here reading people being able to embrace MANY "interpretations", and use them to expand knowledge and probe hypothesis. Both about new experimental testing, or even simply on the internal coherence of the theory.Lord Jestocost said:Some commenters here on PhysicsForums don’t seem to grasp that their “interpretations” merely reflect their “feelings” of what “relality” “ought to be”.
Your personal feeling seems to be that there "ought to be" no better explanation out there. I found that hypothesis very un-scientific.Lord Jestocost said:In case you need your "ensemble interpretation", that's o.k.. But, please, be aware that's your personal "feeling" of what "ought to be out there".
Boing3000 said:All statements about QM are made about classical FACT (not ideas, nor conceptions).
Your implicit interpretation is the source of the "consciousness" nonsense.
"Quantum phenomena do not occur in a Hilbert space. They occur in a laboratory"Lord Jestocost said:What the heck is now a "classical FACT"? And what is exactly my "implicit interpretation"?
QM, or rather QED, precisely tells you what a photon will do when send through a double slit. Hitting the detector/photo plate, it will leave a spot with a probability given by the corresponding probability distribution for hitting the photoplate at the observed position. With a single photon, of course you cannot check, whether the predicted probability distribution is correct. For that you have to create an ensemble of single photons large enough to let you measure the corresponding pattern on the photoplate and check whether it confirms your prediction.Boing3000 said:"Quantum phenomena do not occur in a Hilbert space. They occur in a laboratory"
Your implicit interpretation is that QM can tell something about what a photon will do when send into two slit. QM cannot. Saying that nobody should be interested by this problem is "your" interpretation, called "shut-up and calculate", that posit the extravagance of the existence of some probability space (and nothing else).
But there is a chance I get you wrong...
Exactly, and I find quite bizarre that you qualify "hitting the plate (anywhere) and leave a spot", a precise statement.vanhees71 said:QM, or rather QED, precisely tells you what a photon will do when send through a double slit. Hitting the detector/photo plate, it will leave a spot with a probability given by the corresponding probability distribution for hitting the photoplate at the observed position.
That's the point, isn't it ?vanhees71 said:With a single photon, of course you cannot check, whether the predicted probability distribution is correct.
This is fine, and useful "mind trick". Certainly one that will ultimately be useful to build some fancy macroscopic apparatus, or obtain useful information from a huge number of event.vanhees71 said:For that you have to create an ensemble of single photons large enough to let you measure the corresponding pattern on the photoplate and check whether it confirms your prediction.
What a photon does is realm of interpretations. I think you ascribe too much to bare QM and QFT.vanhees71 said:QM, or rather QED, precisely tells you what a photon will do when send through a double slit.
Boing3000 said:Your implicit interpretation is that QM can tell something about what a photon will do when send into two slit. QM cannot.
vanhees71 said:What do you mean by "intrinsic nature of phenomena"?
