Does Increasing Downforce Help a Car Stuck in a Hole More Than Pushing It?
  • Context: Undergrad
  • Thread starter Thread starter Rock_Sniffer
    Car Hole Stuck
The discussion revolves around the mechanics of a car stuck in a hole and whether increasing downforce is more effective than pushing the car from the back to help it get out. Participants explore the concepts of friction, force, and traction in this context, considering both theoretical and practical implications.
  • One participant proposes that increasing downforce could reduce the work needed to get the car out of the hole, suggesting a need to calculate how much additional downforce is required.
  • Another participant argues that pushing down on the car may not help it escape the hole, questioning the effectiveness of increasing downforce.
  • A different viewpoint suggests that while increasing downforce increases friction, it also increases the weight that must be pulled out, potentially canceling out the benefits.
  • Some participants note that pushing from the back may be more effective as it increases traction without adding to the weight that needs to be moved.
  • One participant highlights that the depth of the hole and the material (like mud or snow) can significantly affect the situation, indicating that different conditions may lead to different strategies for getting the car out.
  • There is a mention of the potential issue of one wheel spinning due to the differential, which could complicate the situation further.
Participants express differing views on the effectiveness of increasing downforce versus pushing from the back, with no consensus reached on which method is superior. The discussion remains unresolved, with various factors influencing the effectiveness of each approach.
Participants acknowledge that the effectiveness of each method may depend on specific conditions such as the depth of the hole and the type of surface involved, which introduces additional complexity to the problem.
Rock_Sniffer
if my car is stuck in a hole...
I'm just doing a taught experiment, and i want to be able to prove or not that pushing down on a car that is stuck in a hole(increasing down force) uses less work force than pushing it from the back.
edit: what i came up with is- ASSUME my car is 10kg and it takes 100N to get out of the hole, but it is only exerting 60N.
so a=6m/s^2 and it is required an extra 4m/s^2 to get out.
down force is 9.81*10=98.1N
how much more do i need to get out of the hole?
The friction would exactly balance the force exerted by the car to get out (60N) so there would be no acceleration till it crosses the 100N mark(limiting friction)
Also, I fail to see how pushing the car downwards would help get it out of the hole. Could you please elaborate it?
down force increases friction... according to my regents physics essentials textbook. oh i see we need 100n for the friction to be enough to take it out.
so what i am saying is that we need 40n pushing from the back, how much do we need to increase down force to take it out?
Down Force= 9.81m/s^2*10kg=98.1N
okay let's simplify the question. the car can only exert 60N so let's say we need 40N to move it. (10kg)
coefficient of friction is F/W = 40/98.1= .40775
Just my 2 cents.
Usually the problem with being in a hole, is lack of traction.
The engine usually has enough power, but without traction it can't climb out.
If you increase the weight, you do indeed increase the friction.
But you also increase the weight that must be pulled out.
This tends to cancel out a bit.
Pushing from the back means that the weight is not increased, but the friction against the front of the hole is increased, which is exactly where you need the traction.
This is more effective.
Of course, it's usually easier to just sit on the part of the vehicle that's in the hole...
so what are you saying, applying force to the part that's in the hole is eaiser than pushing from the back? that's what i am trying to show mathematically.
EDIT: i was assuming the car can only exert 60N and it needs 100N to get out, so an additional
40N of force from the back or increasing the down force by X amount so that 60N from the car is sufficient.
Find X and see if it is less than 40N; hence less force than pushing from the back.
I'm going for a qualitative approach before trying to calculate anything.
If the hole is deep enough (deeper than the axis of the wheel), it's impossible to get out without pushing from the back, or up.
If it's not that deep, it may be possible to sit on it to improve traction, but pushing from the back, or up, can also work.
It depends entirely on the type of hole, the slope, and the material involved (mud or snow?).
Btw, one of the typical problems is that the other wheel starts spinning, due to the differential in the axis.
But there are tricks to handle that too.
hmmm i see. i was just trying to show if pushing from the back is less or more efficient than
increasing downforce. i guess it depends.
  • · Replies 41 ·
  • · Replies 69 ·
18K
13K
  • · Replies 76 ·
9K
