Does it matter if L + epsilon is not in the range of the function?
The discussion centers around finding the value of delta (δ) for the condition 0<|x - π/2|<δ and |sin(x) - 1|<0.2. A participant graphed the sine function and noted that L + ε exceeds 1, raising concerns about the feasibility of the solution since sin(x) cannot exceed 1. However, others clarified that as long as the inequalities L - ε < f(x) < L + ε hold true for the specified δ, the solution is valid. The consensus is that the calculations are correct and there is no conflict regarding the conditions set in the problem. The discussion concludes that the initial concern about L + ε being greater than 1 does not impact the validity of finding δ.
rakeru
Use a graphing calculator to find \delta
when
0<|x - \pi/2|<\delta and |sin(x) - 1|<0.2
I don't think there are any other than the format of the previous information:
0<|x-a|<\delta and |f(x)-L|<\epsilon
Okay, so I used the graphing calculator to graph sinx, y=1.2 and y=0.8
The thing is, L + ε turns out to be greater than 1, so I have something like this (i attached a picture).
For \delta I got 0.61. I'm not sure if it's possible, because the line y=1.2 doesn't touch the graph of sinx. Is it possible?
Thank you!
when
Thank you!
That's just fine. Sure, sin(x) never exceeds 1.2, so you don't have to worry about that case.
when
Thank you!
No.
Edited:
You just need to have ##\displaystyle \ L-\varepsilon < f(x) < L+\varepsilon \ ## whenever ##\displaystyle 0< \left| x-a \right| <\delta ##
Uhm, okay. So... who is right?
I don't quite understand what L-ε < f(x) < L -ε means. Do you mean L - ε < f(x) < L + ε ?
I'm not sure what SammyS is on about. If |x-pi/2|<0.61 then |sin(x)-1|<0.2. At least approximately, as your graph is showing you. I don't see any problems with what you did.
Mainly a typo.
I'll fix it.
SammyS said:
Mainly a typo.
I'll fix it.
Ah, ok so your "No" was answering the "Does it matter" question in the post question and my "Yes" was answering the "Is it possible" question posed by the OP in the post. No conflict.
  • · Replies 20 ·
