Does -ln(-∞) Equal ln(∞) in Complex Analysis?
10 replies · 4K views · last reply
DrCrowbar
For instance, say I have
-ln(-∞)​
Does the negative sign on the natural log cancel with the negative sign on the infinity?
Is this true?
-ln(-∞) = ln(∞)​
Thank you
-Drc
Hi DrCrowbar! :smile:
There is no such thing as the ln of a negative number. :wink:
(unless we're allowed complex numbers, in which case eg ln(-1) = πi)
Hi Tim!
Ah... clumsy me. I knew that. I really did. Well, used to... :wink:
So if you have ln(-∞), is that essentially ∞ or -∞?
I'm finding the solution for a calculus III improper integrals question. I guess it doesn't matter, though, because either way it diverges (a possible solution).
Thanks again
-Drc
DrCrowbar said:
Hi Tim!
No, it's simply not defined, as tiny-tim said. I'm assuming you're working with real numbers.
No, that's ∞i :wink:
Ah, ok.
So ln(-#) is the same as -ln(#)... That makes sense, actually. I had forgotten what the graph of the natural log function looks like.
Thanks guys. It's the first time I've asked a math question online and actually received a correct answer!
-Drc
no it isn't!
ln(-#) is an imaginary number (something times i)
if we're only allowed to use real numbers, then ln(-#) doesn't exist!
Oh, ok.
So you can have a negative natural log function (-ln|cscx+cotx| for instance) but you cannot have the natural log of a negative number unless you involve imaginary numbers.
I haven't really seen much of imaginary numbers, but I hear they're used a bit in D.E.
yes, they'll be useful later
for now, forget about them
the graph of ln(x) is like the graph of √x …
it simply has no value for x < 0
What?? In what context is [itex]ln(-\infty)=\infty i[/itex]? What does [itex]infty i[/itex] even mean?
