Does metal film resistor work at cryogenic temperature (3K)?
The discussion centers on the performance and reliability of metal film resistors, specifically Nickel-Chromium (NiCr) alloys, at cryogenic temperatures around 3 Kelvin. Participants explore concerns regarding superconductivity, resistance changes, and the implications for use in dilution fridges and microwave attenuators.
  • Experimental/applied
  • One participant expresses uncertainty about whether a metal film resistor will survive or become superconducting at 3K, seeking references for confirmation.
  • Another participant notes that while Nickel is not superconducting at 3K, Chromium transitions to superconductivity at that temperature, raising questions about the behavior of the alloy.
  • A participant shares personal experience, stating that the resistor will function but warns that resistance may change, suggesting testing at 4K for better understanding.
  • Concerns are raised about the potential for some Chromium alloys to become superconducting at lower temperatures, advising caution when mounting resistors in sensitive areas like the mixing chamber.
  • One participant mentions that their supervisor indicated NiCr alloys are used in cryogenic microwave attenuators, implying they can operate at low temperatures without superconducting.
  • Another participant highlights the importance of the dielectric properties at 3K, emphasizing that the dielectric is critical for capacitors, which may be affected by temperature changes.
  • A later reply cautions about the reliability of attenuators at very low temperatures, noting that while many work at 4K, not all are suitable for mK temperatures, and recent changes in manufacturing may require special cryogenic attenuators.
Participants express a mix of personal experiences and theoretical concerns, with no clear consensus on the behavior of the resistors at cryogenic temperatures. Multiple viewpoints on the reliability and performance of NiCr alloys remain unresolved.
There are uncertainties regarding the specific behavior of Chromium in the alloy at low temperatures and the implications for dielectric materials in capacitors. The discussion also reflects varying experiences with different brands of attenuators and their performance at cryogenic temperatures.
Sandbo
I am trying to use a metal film resistor to limit the current inside a dilution fridge (to reduce noise power from it), but I couldn't confirm if the metal film resistor is going to survive (or it goes superconducting) at ~3 Kelvin, searching a bit on the web but still I couldn't find the answer, much appreciated if you don't mind providing me with some references.
Looking up on the manufacturer's website for the composition, it said the resistive elements are mainly Nickel(97.72%) and Chromium(2.28%).
Nickel is not superconducting at 3K, however Chromium just goes superconducting at 3K.
Nickel is magnetic which would surpass superconductivity, still there is an uncertainty about how the Chromium would behave.
It will work fine (I am talking from experience) . However, note that the resistance will change. How much, will depend on the initial resistance value (or small values it be something like a factor of two) so your best bet is to test a few resistors at 4K in a dipping dewar.
Also, it is usually best to use surface mounted resistors. The reason is that larger resistors can -if you are unlucky- eventually break due to the thermal cycling.
Btw. some Cr alloys will indeed become superconducting; but at much lower temperatures (a couple of hundred mK), so be careful if you are mounting resistors on the mixing chamber.
Thanks a lot for your replies,
I talked to my supervisor, he said the NiCr alloy is used also in the cryogenic microwave attenuators we are using in the fridge, which means they can stand low temperature without going superconducting. In this case I will go ahead and use it for now, and as you suggested I think I should get some panel connectors and use the surface mount in the future.
Biggest issue in my mind is what happens to the dielectric at 3K...since caps are E field devices, the dielectric is more important then the conductors.
Tell your supervisor to be careful. It is true that virtually all attenuators work at 4K, but only some work at mK temperatures since most become superconducting. Hence, be careful if you are installing attentuators at the mixing chamber (which you usually have to do). It used to be that standard attenuators from some companies worked well (e.g. attenuators from XMA) meaning you only needed to know which brand to buy. However, in the past few years they all seemed to have changed something so nowadays you usually have to buy special cryogenic attenuators (which are quite a bit more expensive) if you want to be sure that it will work.
10K
